B1750 HST Implement usage
Hardtke
B1750 HST
May 14, 2017
Cross Plains Tennessee
Hello all, new here and also as new as it gets to owning, and operating a tractor. I bought a B1750 HST at a great deal and am going to buy a box blade. This tractor already has a belly mower on it. My question: Can use the box blade (raise/lower) with the belly mower still on? Thanks!!
OrangeBX
Bx2680 FEL, MMM 60", EA 5' rear blade, lp ph10 auger, 50" tiller
Apr 24, 2016
45
North of Zachary, La
Is there s knob on or near the floor with numbers on it? If its like my bx, it will have a setting called "TOP". This setting will allow you to use the rear lift fully without lowering the mower. One tip; you might have to raise your deck to the upper stop to turn the dial to TOP.
On mine you have to raise the deck higher than the current setting to move the dial at all.
Good luck with your new 1750,
DB
Hardtke
B1750 HST
May 14, 2017
No, there's no kind of lever or anything with numbers on it. As soon as I can figure out how to up load pics I'll share em and see what yall think. I think mines a 1996
Grizzy3901
L3901hst, la525, 72" landpride finish mower
Jan 1, 2017
67
Bealeton va
If your talking about the lever on the floor board No that is your rear diff lock. Use it when you want both rear tires locked together for better traction.
10,409
On some of the older models there is a latching system that will hold the mower deck up and allow you to use the three point separately, I'm not sure on yours.
Look at the deck for a lever or a latch. ;)
Hardtke
B1750 HST
May 14, 2017
Yeah I'm not sure.. if it has one it sure hides well. It's defiantly an older model but runs great! I'd just hate to take the deck off every time I use the box because I'll use it alot and I found that the PTO is a pain to hook back up with one person :(
