OK, thanks for the info. I tried to tighten already and it was snug. I think the leak is coming from the other side of that thing that is bolted. I will clean it up and check again. Thanks.Might put a wrench on that "banjo bolt" and be sure it is snug. If that is where it is leaking and the bolt is tight there is usually a flat copper seal on both sides of the banjo. You'd need to replace those.
Before taking anything apart analyze the problem to be sure what you're trying to do.
Clean the area real good with pressure hose. Run the tractor and watch for actual leaks. Sometimes you can put a paper towel there, as you run the tractor, and see it it absorbs oil.
Ok thanks.If memory serves that line was kinda of a problem child with that tube cracking at the braised area where the banjo meets the tube. You may get lucky and replace the sealing washers at the banjo fitting?
Pat
Well you were right the tube had a crack in it. Had to take it to Kubota dealer to get it fixed.If memory serves that line was kinda of a problem child with that tube cracking at the braised area where the banjo meets the tube. You may get lucky and replace the sealing washers at the banjo fitting?
Pat
When the arms hit the fully up position, the relief valve opens and the pressure is at maximum.Just came across this thread in a search and my B1700HST has the same leak point at the brazed connection to the Banjo fitting. I found it happens only when I raise the rear arms to the fully up position. It's like the pressure builds at that point and then the leak starts. Is this a return line (i.e. no pressure) or a feed line to the FEL that is always under pressure?
Thanks
When the three-point arms are fully raised the relief valve should not open, the control valve is shuttled to the neutral position. If the three-point feedback link is adjusted too short when fully raised the piston -to- rockshaft arm will contact the rear axle center housing and continuously blow the relief valve, which it should not do.When the arms hit the fully up position, the relief valve opens and the pressure is at maximum.
True.When the three-point arms are fully raised the relief valve should not open, the control vale is shuttled to the neutral position.
Thanks for the reply. I figured something like that was happening. Was hoping I could get away with a quick fix using JB Weld but looks like I need to bite the bullet and replace the line. Looks like it will be a pain to get it out.When the arms hit the fully up position, the relief valve opens and the pressure is at maximum.
Snekypete,Thanks for the reply. I figured something like that was happening. Was hoping I could get away with a quick fix using JB Weld but looks like I need to bite the bullet and replace the line. Looks like it will be a pain to get it out.
