Update to similar issue with my 1993 B1750, dated, 04/01/20, above.Just an update on this,. Called my local dealer and on my B1700 there is no relay. From their experience they are looking at one of two things. The first is the positive battery cable and the second being the harness itself. Need to pull that center console off after I wrestle that roll pin out of the throttle handle so I can access that harness. But first I'll get on that power cable from the battery and check it out.
Due to lack of other options, I did replace the key switch some time ago and, initially, it once again appeared that the problem had been solved but the intermittant no crank issue returned within a short while.
Recently, I again inspected the fuseable link in the wireing harness at the solenoid, again finding nothing wrong. Still, Kubota saw to fit to include a spare (along with a couple of conventional fuses) with the materials delivered to me with the tractor in 1993. Since I had a new one, I installed.
Yet again, it appears that the problem has been solved but it has been only a few crank cycles since doing so.
If the problem returns, I plan to build and install a new battery cable (about 40") to connect where the battery negative cable bolts to the transaxle beside the seat, and one of the starter mounting bolts.
Running out of options, here.
SDT
