Attaching to rear hydraulics
motor2of7
B7200HST w/ loader & backhoe
May 31, 2012
Oakhurst, CA
Hi, I'm new to the forum but from what I've read you folks know your orange tractors.
I have a B7200HST. I want to start using implements that attach to the 3pt hitch, some of which will tie in to the rear hydraulics, like a log splitter.
In the case of a splitter I've deduced that I need to pay attention to open vs closed control valves but I'm unclear on which one I need to use. Help!
Does anyone know the PSI and GPM ratings of the rear hydraulics?
Also, what QD fittings do I need to add to my tractor (supplier and part nos if you have them)?
I'd also be open to specific recommendations for splitters that will work with this tractor.
Thanks in advance.
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Tractordata.com claims around 4gpm which is too small to run a splitter. The 3pt pump is too small to run a splitter effectively. You would need a PTO mounted hydraulic pump or on installed on the front PTO (crankshaft).
