Attach box blade with a quick hitch
Dae06
2019 Kubota B2650 Cab.
May 10, 2018
173
Minnesota
If I don't have my digging tines down at all on my box blade, I can't get my quick hitch down far enough to connect/disconnect the blade. I currently need to put the box blade on blocking. Is that normal? (B2650 Tractor), If so, what kind of nifty ideas are out there to keep the box blade up when stored so the next hook up is easy. I currently am use a couple of 4x4's, but am looking for any better/more ingenious solutions.
Thanks
Clover13
220
NJ
Curious about this one myself as I'm about to pull the trigger on a B2650. What QH do you have installed?
For moving implements around, many guys use automotive dollys to move them around or store them in a tractor accessible place on a pallet.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,522
548
That's odd? I have a quick hitch on my B2620 and have no issues with any implement except the Wallenstein BXM32 chipper shredder. I had to put feet on it because it was too low for my B and my neighbours BX.
10,982
Pictures of what you are dealing with will sometimes give you a lot more answers! ;)
Dae06
May 10, 2018
173
Minnesota
I'll try to remember to take pictures this weekend.
Clover13: 2018 Land Pride QH05 Quick Hitch
rademamj
Waco, Texas, USA
Check your top link. Perhaps your top link is restricting how low the quick hitch can be dropped for the connection. Occasionally, I do use short pieces of a 6x6 to elevate the implement...for a really fast connection later.
Sent from my SM-G930V using Tapatalk
eipo
L4060
Dec 1, 2015
699
85
MI
I have this issue with mine as well.
There are 2 sets of mounting holes on the lower arms... Move the side links to the set of holes closest to the tractor. This will make the effective height when in the lowest setting closer to the ground.
anthonyv
BX24 BX2200
Jan 24, 2017
122
20
SC
I use short pieces of 4x4 to elevate the box blade & land plane, keeps the tools off the ground, & as rademamj says it helps to speed up the connects. Also I think it makes it easier & gives a little more travel to the hitch if the ground isn't level when connecting.
kemosabe
Kubota L2501, 60" Box Blade, Front Loader
Sep 5, 2018
Houston, TX
I place all my attachments/implements on pallets just to keep everything off the ground. Haven't had any issues with getting QH to connect to box blade however I have the L2501.
