Articulated rear loader
Treckerzeug
Carraro tgf 7800 taijfun 4,5 t winch, trailer with crane, double bl saw
Apr 17, 2015
135
19
Bavaria South Germany
Hi,
i've a tight space for corenring with loads of cut logs, so a front end loader is not very practible.
Solution therefore:
A rear loader which pivotes at around 1,3 m from the ground with the fork very close to the rear wheels.
This type of laoders has been developped in South tyrolia, if you want to see one factory made check under
http://www.ilmer.it/de/maschinen/hecklader/produkt-informationen.html
Mine has been made using an old fixed type "STIER" rear loader, a complete kit of FEL mounting parts of a "BAAS" loader and some hydraulic cylinders.
5 days of cuting, welding and mainly head scratching to get cinematics for the tipping without parallelogramme more or less functionable.
Regards
Robert
6,432
Treckerzeug, if you got that done in 5 days you did good!! Like you said the "head scratching" would take more time then the actual cutting and welding. Nice work.
The first picture of the rear loader, it that attached to a Deutz? What model?
Treckerzeug
Apr 17, 2015
135
19
Hi,
Should've been a D6206,
It is the sellers tractor,
I got the loader via e bay for 190€
At 80 km distance
Regards
