Another layer of theft deterrence
Pony Doc
SSV75 Kioti LK3054 Oliver 1250
Dec 15, 2020
32
Central Colorado
Disclaimer: I've been a member for awhile but haven't posted enough to not be a "new member". I have no connection of any type to the product or company I'll be discussing and bought it with no strings attached at full price.
I've wanted to add an electrical circuit interruption option to my machines for theft deterrence for some time but I'm not very sophisticated regarding electrical systems and particularly did not want to cut into the skid steer electrical system. I was frankly looking for plug & play. I came across the EZ-Lock starter lock system, https://inotheft.com, recently. Its a relatively inexpensive starter relay replacement that requires a RF signal from a fob or pin pad for the starter circuit to be energized. They also have the same device in a hardwire variant and have recently added separate GPS tracking devices. This is a small private company & when I had some installation questions I ended up speaking directly to Mark, the owner. He was patient with my lack of electrical system sophistication and helped me resolve the issues. He actually called me back after he shipped me the device to see if I had questions and if the device had met my expectations.
Is it fool proof? No, of course not, if you know its there & have the tools & know how it can be defeated but it would take some time, again its an additional layer of theft deterrence.
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
Or for free you could just remove the starter relay.
Pawnee
L2501
Jul 1, 2021
328
282
Ontario Canada
I think it's a cool idea. Way more convenient than removing the relay.
I have an "extra requirement" wired into my tractor to make key starts impossible but i have to enable/disable it manually, the fob idea eliminates that, the extra security is automatic.
Jay, how could you do a fob activated relay for $12?
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,400
2,321
For a plug n play solution, I like it! One thing to consider- is there a constant battery drain?
4,091
You can get them from Banggood or Temu, about $12 CDN. They're a one channel RF relay unit.
One place/ one version...
Have a 4 chnl version on my BX23s, controls nonROPS forward LEDS and the GDO.
GrizBota
Apr 26, 2023
1,141
726
Oregon
Back in the day, a hidden on/off switch to interrupt either the hot side of the coil (old school, gas engine) or hot side of the starter solenoid would get it done. I suppose the same would work on a tractor with the starter or the fuel shut off. Or pick a safety switch to do the same thing to.
The fob thing is neat, but it’s one more thing to not work someday.
BAP
Dec 31, 2012
2,534
672
Pony Doc, nice write up and it’s good to learn about different products out there on the market. Ignore the critics and those who immediately have to tell you that they can do it better and cheaper and keep posting about the things that you do to improve your tractor. That’s how everyone learns more.
mikester
M59 TLB
Oct 21, 2017
3,155
1,634
www.divergentstuff.ca
I'd say move to Canada so you can just leave the machine outside with the keys in it all the time. On the minus side it's illegal to go hunting with your full auto AR15 with 50 shot magazine and to open carry at wallymart.
Thunder Fish
ZL2202DT-M
Oct 21, 2017
140
38
100 Mile House BC,Canada
Yes I do but with a 16 speed manual transmission,no lock on the tractor shed
4,091
It's only illegal IF you get caught AND charged....
As for my previous comment, I offered an option to that device. while it may work as advertised, some can't afford a Bentley, but can buy a Beetle.
It's always important to have options.
Pawnee
L2501
Jul 1, 2021
328
282
Ontario Canada
Wow, i did not know that was available.
Gotta have one.
Idle current is <10mA
4,091
Well whatever you can think of in electronics has already been made or can be !
I don't know hwy the Idle current is so high though. The one I designed and built draws 1/10th of 1ma ( aka 100ua )
What I found crazy is a 'wireless trailer brake controller' that needs an 'ap' run on your smart phone. Something the hackers will love... lockup YOUR brakes while cruising down the highway.......
3,045
Jumper wires or cable can by-pass (directly to the starter) any starter-relay protection in only a moment.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
240
269
SE, NM
Starters are really easy to jump on most/some of these tractors. Something to cut the fuel is an option
Edit; Geohorn beat me to it
4,091
It's always better to open the fuel pump feed than the starter relay. That way engine turns over but engine cannot start. A 'clean' install will be invisible 99.44% of the time.
it's also how EASY it is to STOP thieves from driving away ANY fuel injected vehicle. Car starts, gets maybe 1-2 blocks then dies, can't be restarted,thieves leave ,car stays.....
4,219
For a tractor........a thief only needs to travel maybe 50 yards, to be loaded on the thief's trailer.
fj40dave
Sep 24, 2009
418
255
Yelm, WA
Farmer buddy of mine told me to just engage the PTO lever (after you've turned it off and parked).
