Hi I have a b8200hst and I'm looking to add a 2 spool valve for a snow plow I built. What I need to know is what type of fittings I need to tap into the tractors accessory hydraulic block that's right behind the hst pedal. You're limited in a few ways one being the hst pedal is close to the valve so they can't stick out far, also the ports are close together which may not allow 90deg fittings to be screwed in( have not tested fittings are expensive).
Preferably is like to do a 3/8 bspp which is the block threads to a 3/8 jic 90deg adapter but I really don't think it will screw into the block without hitting the fitting below is
So any thoughts and help especially from you that have loaders and accessories plumbed into your tractors already
PICTURES WOULD BE GREAT
