O Old Mcdonald New member Equipment BX 24 Mar 1, 2014 23 0 0 rye,Tx May 14, 2017 #1 What would be the easiest way to clean out the fuel tank on a bx25 short of removing
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,938 5,291 113 Sandpoint, ID May 14, 2017 #2 I've said it before, use soltron! It is you best possible bet to breakup and remove the algae without removing the tank The other would be to fill with some fuel and pump out the of the inlet and filter it and do it several times. https://www.navstore.com/soltron-enzyme-fuel-treatment-16-oz-500ml-bottle.html
