Air Pressure when using beet juice
fmgsr
Kubota, LX2620 - Kubota BX2380 (retired)
Dec 19, 2018
89
46
PA
I have a BX2380, dealer put beet juice in the tires.
I have R4 tires, 18” and 26”.
Im not in front of tractor so I don’t know recommended pressure is.
But with the beet juice, what pressure difference should I hold to?
Or do I put the recomended anyway?
3,037
Nothing changes with pressure - the "liquids" cannot be compressed, only the air LEFT inside the tire can be.
Thus run the same as you would before .......
the only problem with loaded tires - the air you had before was the only "shocks" you had when hitting a bump - now the air is only 25% of the area inside (typical 75% loaded) - thus you will feel those bumps a little more now!
I run something like 20 psi ( use loader a good bit )on the fronts and 15 ish on the rears......
imnukensc
BX2380
Sep 10, 2015
791
755
Midlands of SC
My rears are loaded with water and antifreeze. I run about 12 psi in the rears. Rarely use or even have the FEL on the tractor so run the recommended in the fronts.
4,063
Just be sure to check your loaded tire air pressures with the valve “stem” in the uppermost (12 o’clock) position so you’re checking actual air...instead of liquid.
