Air Bubbles in fuel line
Lambos
NH
Kubota D1402B a 3 cylinder is getting air bubbles at ONLY #2 fuel line, loosened the connection at the injector to bleed out the air for more than 15 minutes several times any ideas? Thanks!
2,975
Dumb question, how do you know YOU have air in that cylinder?
Could it be a "bad" injector instead or when you crack the injector, is it spitting bubbles and not a solid stream of diesel?
10,136
You have a bad injector, but have all of them rebuilt or replaced. ;)
Lambos
NH
Both#1 and#3 have a solid fuel stream when cracking the fuel line feeding the injectors but #2 has consistent air bubbles?
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
690
299
Herald Calif.
Hello
If you have air bubbles before he injector , the injector is not the problem. The first thing I would check is the tightness of the delivery valves. This is the piece that the injector line attaches to at the top of the injection pump. If one is lose that cylinder will not fire.Remove the lines from the injection pump. Then check them with a 19 MM box end wrench. When did this problem start. Did you run it out of fuel.
Good Luck Lance
Lambos
NH
Yes, I had made sure both ends of the line from the inj pump to the injector was tight, could there be a cracked fitting and not be leaking fuel? Thanks for your input!
007kubotaguy
Dec 23, 2012
690
299
Herald Calif.
Hello
Did you check the fitting below the injector line on top of the injection pump. This would be the nut that takes a 19mm wrench.
Good luck Lance
Bram52
MT50
Oct 1, 2017
Qld Australia
No change still seeing bubbles on only #2 fuel line ???
Check dipstick to see if you have any increase of oil in your oil pan ,if you have you it's most likely fuel adding which means you probably have a worn injector element in you injector pump, It would explain why you are getting air in your #2 injector ,, the tolerance is very fine and any wear will show up with those symptoms.....
Lambos
NH
Hello
Good luck Lance
Thanks!
Double checked and all lines and fitting are tight but still getting air bubbles at the #2 injector the other two are fine.
Could the fitting on the fuel line to #2 be sucking air or the injector pump be introducing air to only #2?
Appreciate all input!
