Ag wheels for my 1990 B7200 HST 4wd?
Hardboiled
B7200 HST 4WD
Oct 17, 2025
Connecticut
Hello everyone looking to swap over to so Ag rims ad tires for this sweet B7200 I just picked up. 1300 hrs in excellent condition . It came with a mower deck and 2030 plow.
I would like to pick up some Ag rims and tires s I can put chains on it and plow this winter. Looks like they still offer front 6-12 #70000-00441. The back rims though I am not sure about. Looks like I could go with a 8-16 or a 9.5-16.
Anyone know what my options could be? Thank you!
9,266
There is no 8-16 used on that model.
The 9.5 16 is the only option.
Hardboiled
B7200 HST 4WD
Oct 17, 2025
Connecticut
Okay thanks. Now the hunt.
I'd try chains on those first ...
Thanks for the input. Yeah I considered it. I was told that Chains on turfs is not ideal due to shifting, My property is a bit rough and I think the ags will be bette5r for my situation. I do want to keep the turfs so I have both options.
Shawn T. W
Dec 9, 2024
372
651
SW Missouri Ozarks
Unless you get chains similar to these ... https://www.tirechainsrus.com/produ...or-tire-chains/?attribute_pa_full-size=9-5-16
If your plowing a driveway most people are happier with the turfs on smaller tractors ...
I found regular "ladder" chains just slipped down in-between the lugs .
If you want AG R1's then by all means but what you want, just trying to save you some money ... I have R4's and use chains on that tractor . . . https://www.orangetractortalks.com/forums/threads/diamond-or-2-link-ladder-chains.77194/
N3BP
Sep 20, 2016
504
236
Lebanon, PA
The front 6-12 AG rim for the B7200 is common and used across wide variety of machines, so that is the easy set to find. The rear 8-16 rim (for 9.5-16 tires) is rare and specific to the B7200 alone due to it's offset.
However, I was able to locate a rim that worked out for me. See attached part number as well as what they looked like on the machine.
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
126
124
Stafford, VA
Is it the picture, or me? It looks to me as if the ag tire tread on the rear tire is backward…it opposes the ag tire tread on the front tire.
N3BP
Sep 20, 2016
504
236
Lebanon, PA
You are correct. That year, I thought I'd try reversing them for 3PT snowblower operation. Made zero difference, so haven't done it since. Matter of fact, I stopped using the Ag's all together for snowblowing. The turf's do just fine.....
Hardboiled
B7200 HST 4WD
Oct 17, 2025
Connecticut
Thank you for the info I will look into that part number. Going to get ags eventually.. maybe. but in the meanwhile I just purchased some trygg chains and matching fronts for my turfs. I know I should be good in the winter its the summer I may need some more traction but now at least the chains will be there.
N3BP
Sep 20, 2016
504
236
Lebanon, PA
The two areas I find the Ag's to be superior is log dragging through the woods, and plowing with the back blade (pulling the blade from behind where you drive over snow before plowing it).
If your plow is front mounted, you might be surprised how well the turfs work in 4wd, even without chains.
