Adjusting 3pt lift lever..?
Drifthopper
2000 L3710 HST w/ Woods 1012 FEL. LandPride FDR2572, 60" Brush Hog: Need 60" BB
Apr 22, 2022
86
65
Western New York
Is there a way to adjust the 3 point lift lever to get more travel on the lever..?
It is numbered from 1 to 8 , but my lift arms don't start to move till at around #4 , maybe 4 1/2..... 1 thru 3 have no effect , no arm movement.
Tractor is a L3710
Thanks..!
hodge
Nov 19, 2010
2,950
514
Love, VA
Do you have an implement installed? If so, it is probably holding the lift arms up. In other words, if there is no implement installed, the arms will go all the way down. In that condition, moving the lever from 1 to 3 will probably lift the arms up to implement height.
Drifthopper
Apr 22, 2022
86
65
Western New York
Hodge .... I have a finish mower on there now, but it makes no difference whether there is an implement attached to the three-point or not.
It is not a big deal , but it would be a little bit more convenient having more travel on the arms to adjust the brush hog when mowing with that.
5,696
I looked at 'parts', there's no adjustment on the lever BUT there IS on the 'feedback' linkages. It may (or not) be possible to adjust it to be more 'sensitive' or 'when' feedback actually takes effect.
However as long as the 3pt is fully up at '8', I'd say it's 'working'.....
It would be nice if the lever position did represent the actual position of the 3pt though.
