Adding fuses to the fuse block for L3901
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
67
Minnesota
Anyone add power to the unused spaces on the fuse block.
Or are you adding an accessory fuse block for light and other power add on?
3,619
I added in-line fuse holders next to the fuse box. A piece of tape with the item-name on it wrapped around the fuel holder identifies it’s purpose.
lugbolt
ZG127S-54
Oct 15, 2015
5,495
2,200
Mid, South, USA
Easy peasy if you have the correct terminals, wire, and crimpers.
--or-- if you have another fuse block to remove the terminals and partial wire from.
Orange1forme
Dec 1, 2018
397
60
Wa
I added a second fuse block.
I could not find the terminals and it seemed like it would be easier than trying to supply power into the existing block.
Also easier when you want to add another circuit to add to the external block rather than the existing.
