I have a 2017 900X with 340 hrs. I changed all fluids/ filters at 60 hrs, and filled with premium synthetic hyd fluid for max protection at low temps (-40). I have used this oil in other applications for years and it has been great. We don't use it when it's cold but I wanted the protection in the event that we may have to have had a cold start for some reason. The oil supplier advertises extended drain intervals, recommended changes at 600 hrs. I believe that the manual says filter at 200 and fluid change at 400 hrs.
The hyd fluid condition was good, it was a bit darker but that was it.
However, the fluid out of transmission was very dark and seemed to a silver tint to it with I am assuming are metal cuttings. The magnetic drain plug was cover with fine cuttings almost like pollen on a flower.
Did anyone else have a similar experience when they drained trans oil? Is this something to be concerned about? I definitely will change the trans oil and filter more often going forward.
Thanks to all who respond.
