8-16 vs 8.3-16
phaser
B7100HST 4x4, FEL, field mower
Aug 6, 2013
171
Oregon
What does that first number refer to, and what's the difference between the 8 and 8.3?
9,999
Width and height ratio, it's 8" wide but that also effects the height and the RC of the tire.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Both of those numbers are the section (- overall -) width of the tire. The 8 is 8 inches wide and the 8.3 is 8 and 3/10ths of an inch wide. Some front R1 tires by different manufacturer's make them different sized probably to gain flotation maybe. If you're looking at the difference because you need to replace some tires find out what the rolling circumference is and if it's within 2% you're good to go.
Al
