I just purchased a M6950DT with a front loader. Everything seems to work fine except for when I hooked up a 6ft mower. The PTO is slipping/stopping under load. My fear is it is the PTO clutch. Could it be something else?
I do not think it is the Clutch. Could it be the PTO Clutch. I believe it is in the rear of the tractor and not with the Drive Clutch. Dors anyone know?A friend of mine bought a used M9000 and after hooking a baler to it found that the pto was slipping. Long story short the hyd pressure was low going to the pto but in the mean time the clutch pack was destroyed. New clutch pack and fixed the pressure issues and it was good as new.
The PTO clutch is what I was talking about.I do not think it is the Clutch. Could it be the PTO Clutch. I believe it is in the rear of the tractor and not with the Drive Clutch. Dors anyone know?
Ok, if u have a live PTO, your PTO is going to slip in one direction but it shouldnt just stop, also your clutch is a dual disc clutch. in other words, push the clutch pedal half way in that disconnects the input shaft from the PTO part of the clutch push it all the way in that disconnects the input shaft from the drive part of the clutch.The PTO clutch is what I was talking about.
Unless I'm just completely off base this tractor has independent PTO instead of Live. It doesn't have a dual clutch, it's a single dry disc.Ok, if u have a live PTO, your PTO is going to slip in one direction but it shouldnt just stop, also your clutch is a dual disc clutch. in other words, push the clutch pedal half way in that disconnects the input shaft from the PTO part of the clutch push it all the way in that disconnects the input shaft from the drive part of the clutch.
(i believe thats how it work)
The fluid and filters are good. I think the tractor has a pto pump and not a clutch. Does anyone know?Thanks,
I am going to work on it tomorrow. I will let you know.
I was advised by a Kubota tech that it has a hydraulic pump and he believes there is a restriction somewhere. We are going to check the pressure.According to Kubota parts which BTW are now accessible for free online your tractor has a hyd pto clutch.
Does any one know what the pressure should be?I mentioned low hyd pressure on 6-26.
