640 g6200 injection pump module timing
Hal k
G5200 g6200 l245 jd 345 jd z910a jd5045e
Feb 4, 2022
Tallahassee fl
Have new module to install. I am a little perplexed by the flywheel timing marks and procedure because the engine is reversed. Any help please. Thanks
10,480
Do you have all the original shims?
If so put them under the new pump and run it!
There really is no need to try and retime it.
The direction of the engine sitting in the unit does nothing as far as changing the timing, it's still the same procedure.
