3rd function for front loader.
chipruss
70 & 90 hp Kubota tractors
Apr 4, 2021
When I purchased the 7090 a couple of years ago, I had a 3rd control installed for the loader. I have finally purchased a grapple and found that the B button on the control does not work. The A button works, but no response from the B button. I switched lines and A button closed the grapple but must be a wiring issue. Any thoughts or help? Activation button works, just no response from B.
3,871
look for a broken or disconnected wire inside of the button assembly. That would be the first place to look, and then do a connectivity test of the wires. If you have a schematic of the wiring, it will make it easier, but I would assume that it goes from the battery to the switch out to the relay, and that everything uses the tractors ground. Since one button works, and the other doesn't I will assume that the ground is good.
