3 point wont raise.
goosekiller
all
Aug 6, 2016
mt.vernon in
I have a bx2660. The mower deck has seemed to be getting sluggish raising. Today I was brush mowing with bush hog. The 3 point was working fine. Then while tractor was revved up it sounded like the lifting lever was making a whining sound like it was stuck like the noise you get when your holding lever in the up position. The 3 point wont lift at all. I have not tried the bucket yet. It just happened bout hour ago. It sounds like the lifting lever is stuck in the up position. Any Ideas out there. Gonna take off bush hog in the morning and try the bucket to see if it works.
goosekiller
all
Aug 6, 2016
mt.vernon in
Well unhooked bush hog. Hooked up bucket but it wouldn't raise unhooked hydraulics again then reattached them and everything is working fine. Guess its time to change all hydraulic fluid and filters. Must of been something blocked and moved on through the system after hooking up bucket. Still would like some comments on this issue. to see if anyone else has ever had this issue before.
9,171
Yep, quick disconnect wasn't allowing fluid to flow. ;)
