3 point hitch
ferguson
L3130
Jan 19, 2022
293
114
w.v.
New to kubota's have a L3130 / 3point hitch will not lower worked a week ago / has bin cold hear teens & 20's frozen ???
2,227
You have anything ON the 3 point? Or is it in the air by itself?
Does that tractor have the down pressure adjusting valve?
Stand on the arms and hit the lever - (might be a challenge to do) and see if it will go down.
You have "new" fluid in the hydraulics? Last filter change?
Does the FEL work? - maybe you do not have one installed.
ferguson
L3130
Jan 19, 2022
293
114
w.v.
Cyl only have high pres, hose on the bottom / have a blade on hitch used it 2 or 3 weeks ago / have 6ft pipe extended on blade "O" movement / hyd loader works fine / have had heater on tarp over 1 hr "O" Movement
ferguson
L3130
Jan 19, 2022
293
114
w.v.
Bisleybob
B7500
Aug 15, 2020
55
Harding Pennsylvania
There should be a knob, between your legs as you sit in the seat that will adjust the flow of fluid leaving the cylinder, therefore adjusting drop speed. Loosen it up
ferguson
L3130
Jan 19, 2022
293
114
w.v.
Shut off valve right down in front of seat ""DA"" ME /Thanks for the response / Nice site / used yesterdays tractor form many times & still will have to TO 20
Crash277
BX23S
Jan 17, 2021
846
622
spin that knob once in a while to help preventing it from seizing up. Every time I run my grease gun on my little BX I adjust it open. Close it. Then Count back to where I have it set.
