3-point hitch lowering speed knob question
treclark
L3800 HST 4WD, LA524 loader, RK 5ft Bush Hog, TXG 5ft Tiller, Ferguson plow
Aug 19, 2025
I bought a used L3800 about a year ago. The 3 pt hitch lowers and raises fine, but the lowing speed knob was frozen. I finally worked up the courage to work on it today. With a little nudge from some channel locks and lots of pb blaster, it now moves freely by hand. However, it is turning multiple times around left and right. I don't want to rotate too far and cause an issue, but i went at least 3 rotations left and back to the right. I was raising and lowering the rear PTO with my 5 ft brush hog attached and didn't really notice much difference in the speed and I never hit a point where it locked and didn't move. My question- I was expecting the knob to rotate about 270-360 degrees to hit the "fast", "slow", and "lock" described in the manual and stop both left and right. Is this normal ? I don't want to turn so many times that I unscrew it. Before you ask, the shaft is spinning, the knob is not stripped.
10,782
It should turn mutiple times, but it does stop at some point.
Save a ton of guess work and remove the assembly (simple remove 2 bolts), completely disassemble, clean and inspect.
treclark
Aug 19, 2025
Wolfman-
Thank you. That makes me feel much better. I'll pull it apart in the next few weeks and service.
Phil
BX23S-1
565
225
No where Special
Every time i get on my tractor, i always reach down and turn mine a few times just to keep it from seizing. I`ve had mine apart a few times, cleaned, lubed, it still turns hard after the tractor sits for a short time. Its just a really shiddy design and engineering flaw.
10,782
Next time you pull it apart, use anti seize on it. ;)
Dustball
2016 B2650HSDC
Sep 15, 2023
516
382
Hudson, WI
Wolfman-
Phil
It's like a water hydrant on your house. Turn it in clockwise all the way to close the flow. Turn it counterclockwise to open up the flow. The more you open it up, the faster the 3-point will drop.
