Hey guys since this 3700 is my first tractor, Im not real familiar with how the TPH should be adjusted. When using a box blade or a rotary cutter should there be any movement? The tractor was delivered with the bushhog attached and it didnt seem to move side to side, until I put the box blade on. Originally it was hanging way left of center, I moved the adjustment bolts so it was center and then tighten them so the box blade didnt move at all. Is this correct? or should there be some play (side to side) on implements
