2018 Kubota ZG327 zero turn with 27hp
1320clout
2018 Kubota zg327 zero turn
May 1, 2023
saukville wi
I bought this unit with 200 hours on it but it was jump started backwards so it cranks but wont start. No fuel pump noise and its blows a 15 amp fuse under seat instantly. I was told maybe a fuel pump shutoff solenoid. I ordered one but can't find where it goes. Help please
lugbolt
ZG127S-54
Oct 15, 2015
5,506
2,213
Mid, South, USA
could be a ton of things
generally if a fuse is failing there is "usually" a short circuit somewhere (short to ground). Look at the wiring harness VERY well for evidence of burnt areas. I wouldn't be buying parts until you find out what exactly is wrong as Kubota parts aren't known to be inexpensive, and on this series of mower, those little parts can add up quickly.
whitetiger
Nov 20, 2011
3,328
1,747
Kansas City, KS
The fuel shut-off solenoid is mounted on the carburetor, see the attachment.
Unplug the voltage regulator and see if the fuse still blows.
