2010 L3400 HST starting issue (148 hours)
Tab
L3400
Jun 7, 2015
Helena, Mo
Tractor sat all winter (3+ months). Started right up and drove it around for 15 minutes. Would not start a week later. Would turn over but no smoke.
Had battery tested and charged. Took off fuel solenoid and it started right up. Did some electrical testing, 12.75v at battery, 12.5v at ignition switch (one contact was rusty and I cleaned it), 10.45v at fuel solenoid.
Bought a Chinese after market solenoid and installed it. No change, put back original fuel solenoid.
Cleaned the ignition switch, fuel Solenoid conections and primary battery ground. Then replaced the ignition switch with a new Kubota ignition switch. Still won't start. Voltage at the fuei solenoid did improve to 11.65v.
Very frustrated.
9,301
The "signal" to the solenoid is not from the hot but from the ground side, problem is probably a bad stop relay.
I would check that out next. ;)
