1977 f150
mudog88
1982 B7100HST-DT, RC60-71H MMM, 5ft. back blade
Aug 11, 2015
100
Pine Village, Indiana
Hello fellow orange addicts!
Just purchased another project. As the title says, it's a 1977 Ford F150. Although it's not orange, (it's been contemplated :cool: ) these particular year range of trucks have a special place for me since my first vehicle was a 79 F100. This one has the 300 L6, with 4-speed granny manual, and 4x4. I know some of my questions would be better suited to post on Ford forums, but I figured with the knowledge, experience and excellent advice I've gained here for my tractor, there's bound to have been at least ONE individual who has some insight. My vision for this truck is to keep it as close to factory original as is feasibly possible. My plan is to use this truck for towing/hauling. My current truck (2006 Isuzu I-350, which is basically a Colorado) is pretty well maxed out on capacity, legally speaking, when towing my tractor on the trailer.
First off, the inverted Y steering system that is on the truck now is completely shot. I have about a half turn of 'play' in the steering... yes HALF! I refuse to drive it on the road until I get that sorted out. Scared the crud outta me when I drove it home. I know the drag link and tie rod ends need replaced. I'm not sure if it has an aftermarket lift or if it's a factory highboy. I intend to keep the ride height where it's currently at.
So, my question is this; provided I am able to figure out whether the current height is factory or aftermarket, would I be able to change the inverted Y steering system to an inverted T system, or should I stick with the original?
The inverted T system is factory on the 78-79 year models, so the parts are fairly cheap with little modification from my understanding. Also, from what I've already researched, the inverted Y steering system was only used on the 76-77 year models. Many of the forums I've read on this topic are for people wanting 4-12 inch lifts, and that's not the direction I want to go with this truck. What experience, if any, do y'all have in this department?
Second, the rust is pretty bad on the frame. What treatment options would y'all recommend?
I'll get some pics up when I get to my computer.
As always, thank you for any and all insight y'all are able to provide!
hodge
Nov 19, 2010
2,963
531
Love, VA
No such thing (as far as I know, which isn't always very far) as an F150 high boy, so it is most likely an aftermarket lift.
"Highboy is not a Ford term. It's a nickname given to the 1977 1/2 and earlier F250 4x4s because they were so much higher than the competition. And all the 1977 1/2 and earlier F250 4x4s were made the same height, it's not an option or lift kit, just a nickname for the standard F250 4x4."
Ford Truck Enthusiasts
mudog88
Aug 11, 2015
100
I had no idea high boy was a nickname. I'd always seen that term thrown around like it was a factory 'feature'. My assumtion was incorrect. Thanks for the insight!
My next step in that department will be to find the factory 4x4 F150 height, then determine how much lift is on it. I knew it was higher than the '79 F100 and '78 F150 that I previously had, but what you've said makes sense now, because I've also owned a '78 F250 and it was higher than both. This F150 I have seems about the same height as the F250. It's difficult to find info because the desire to lift these trucks is so poplular that the stock info gets drowned out.
5,692
All I know is that 300/6 was a beast, not fast but by gawd had beaucoup torque Dad had 3 of them and theres wasnt much he couldnt pull even pulled my Jeep truck out one time,,, never did live that one down,,lol
