12x16.2 air pressure
3,061
Skeets.....
12x 16.2? OR 12x 16. 5?
And yup .......
5,596
Im sure it says 16.5 but I could be wrong I ll have to look tomorrow thanks much
11,101
Look on the side wall of the tire and it will tell you the proper PSI that it should take.
Ikc1990
Kubota m125x, m9000, cat 226 skidsteer and other equiptment
Dec 2, 2020
294
131
Vermont
Remember side wall will show aaand say. Tire pressure but normally that is maximum cold pressure. You dont have to run that much. Example my tires on my pickup say 80 psi. I NEVER run 80 psi even loaded especially in winter. You get no traction. I run 65 psi in them year round and it has a 9.5 foot s.s. vplow and a 1.5 yard sander in winter or dumpfor Equipment or land scape trailer behind. Or round bales of hey in it lumber sawdust etc. She gets used as a real work truck not a jacked up pretty truck.
4,212
Wolfie... is this a TEST? Are you seeing if we’re actually reading with care?
LOL
You are so helpful, and accurate, knowlegeable, and wise in matters..... it boggles the mind to think you believe the pressures on the tire sidewall are recommended pressures for each and every installation.... this must be a TRICK POST you’re making.... ??
The pressures stated on tire sidewalls are in reference to that particular tire’s ability to support the specified weight-capacity of that tire. Example: I have a 5.70X8 trailer tire that states on it’s sidewall “910 lb capacity at max pressure 75 psi”.
The same size tire by the same mfr’r with a different ply-rating on the other side of that same trailer says “725 lb capacity at max pressure 50 psi”.
Those are NOT recommended pressures for that trailer however. That trailer has a 1600 lb GVWR and it’s tire pressure recommendation for 5.70X8 tires is 35 psi. Those tires I have mounted exceed the required carrying capacity of that trailer therefore they are appropriate to be mounted on that trailer...but they should NOT be inflated to their maximum capacities.
Skeets, I don’t know if that 40 psi a mis-print or not, but I suspect it is not a mis-print because the kpa and kgf/cm2 are commensurate. (In other words, it’s the kpa which is likely incorrect so the commensurate psi is also inapplicable.).
However, the TIRE SIZE is only marginally larger than the 11.2 X 16 listed just-above it and so that leads me to believe it IS AN INCORRECT PRESSURE. I believe the correct pressure will be 18-20 psi.
3,061
Geo - while I agree with you -- that chart was from THE MANUAL for his tractor .....
and yes - 40 psi will make your teeth hurt!!!!
Ikc1990
Dec 2, 2020
294
131
Vermont
I think mine on my b 2710 say 40psi I run like 22 to 25 they are turf tires a decent ride traction and never seam to deflated. I'll look tonight but i know I never put more
