12.4 x 16 tires
toddtjs1@yahoo.com
l 2350 dt
Apr 17, 2012
27
pittsford ny usa
any 12.4 x 16 tires out there for sale ?, decent used ones would be fine, really like to find a less aggresive tread than AG if possible.any idea's or tires for sale ?
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Find your nearest Carlsise Tire dealer and aks them what they get for the
12.4-16 Trac Chief R4 industrial lugs.http://www.carlisletire.com/locator/PrxInput.aspx
put in your zip code and it should give you the closest dealer to you for new
tires. Your best bet on a deal would probably be to check with some of the Kubota dealers around you and see if they have any changeovers (where someone bought a tractor with them and wanted turf treads instead) and you might find a deal. Other than that keep your eye out on Craigslist or use
Search Tempest which will search Craigslist first then show any ads on Ebay
to see what's there.
Al
toddtjs1@yahoo.com
l 2350 dt
Apr 17, 2012
27
pittsford ny usa
thanks for the tire info, any idea on size affecting the 4 wheel drive ?, i assume front and back need to stay in proportion so the 4 wheel works right, thinking the outside diameter of a less agressive tire is shorter than a ag tire.
Roadhammer
L2350DT
Dec 23, 2011
19
Sumterville, FL
Tire size is critical on 4wd. If you are not using the factory tires you will need to do some math and the the diameters or circumference of the factory setup to get the ratio if you are planning on changing a tire size rather than matching factory. Operating in dirt won't cut you any slack either. You will end up with an expensive repair bill in the end. Some tire sight list operating diameter but most don't. Good luck. I'm trying to do the same thing on my 2350dt without taking out a mortgage to find some r4 tires.
sgl-350
1983 B8200HST-D, 54"snow blower, 6' back blade, 5' snow blade. Want a loader.
Oct 19, 2011
huntingdon, Quebec
I hear ya,
I`ve been looking for about two years now for some rims and tires for my B8200, with little to no luck. Either they wanted too much (790$ a tire) or they were finished. I just found a set this morning for 275$ an hour and a half from home, tires and rims (all four) off of an old B8200. The guy was a machinist and made the rims out of stainless. I feel even if the tires are scrap, just the rims are worth more. I`m pleased. Best of luck, just gotta keep shopping about.
Steph.
eddy20
b8200
Jan 28, 2014
temecula, ca
Hi All,
Newbie here just purchased a small vineyard in Temecula and with the property I got a B8200 and it needs new rear tires 12.4-16. These tires seem impossible to find; can I use a 13.6 tire instead of the 12.4-16 on the stock wheels? Or can I use turf tires; we do not have much mud. Just found 9.5" X 16" on ebay will these fit on my wheels?
10,744
Hi All,
Read back through the thread, is your tractor a 4WD? If it is it's not as simple as just changing the back tires you will also need to change the front's also to keep the ratio right.;)
Here is one place that has them, http://simpletire.com/titan-12.416-423383-tires
Here is another: http://tires-usa.com/shop_list.php
Here is the tire specs: http://www.titanstore.com/info/423383
trouble11
kubota b9200, bf350fel,b4530 hoe, 2002 Gmc Sierra with plow
Jun 12, 2012
232
Plattsburgh, NY
If You have a local Firestone dealer You can get _Firestone Tractor Field & Road in 12.4 x 16, these are what I use on My B9200. They are R-1
eddy20
b8200
Jan 28, 2014
temecula, ca
BIG THANKS!!! My first post and help within 24 hours. I really appreciate the sources and will start contacting the companies tomorrow.:)
