kubotasam
Here is my newest Craigs list score. A kubota B2781 snowblower with a B2733 subframe. I dug it out of a snowbank yesterday and brought it home.
My first thought was to resell and make some $$. However I am thinking I will keep this and replace the B2650 snow blower that I run on the front or my B 2410 tractor.
The new blower has much larger components and should be much stronger. It also has the hydraulic chute rotator option.
Now for the part that is not so good. The reason I was able to purchase so cheeply is someone tried converting it to run on an LS tractor.
The drive shaft has been lengthened. Also the rear bracket (part# 6) on the diagram is not a Kubota part, it is made for the LS tractor and has been welded to the subframe.
I am missing parts 4,18, 5 & 12. I can purchase new parts, however if I could build the missing parts it would save some $$.
Can anyone help with pictures of the missing parts installed on a B2410 or similar tractor? I have the subframe for LA352 loader mounted on tractor.
Also manual for the blower or subframe would be helpful.
The driveshaft has been lengthed so I would need to recut and bring it back to stock length. I will bring it to a driveline shop but will need the original length if someone could measure one.
