M5140 Instrument Panel separation from Dash
KubotaL185DT
L185 4x4, L245H, M5140HD, Case 580B Hoe, JD350 Dozer, JD LX178,
May 6, 2010
81
Northern Calif
I just bought a used M5140 appears to be a 2012 660 hrs that has a gap between the instrumnent panel clear cover and the rest of the main Dash housing. Gap is about 1/4 inch were moisture and dirt can get into to area. It looks like the entire dash HOUSING is not up tight against the engine firewall. I am going to try and post some pictures. Anyone know how this should be repaired ? I seems that the entire housing needs to be screwed up tight so it fits tight to the engine firewall. Thanks for any help or suggestions. Bill
russell.still.5
197
Lafayette, Alabama
If I remember correctly that piece is held on with 3 screws. One on each side and one in the middle. Have to access all of them from under the hood. The middle one is a pain to get too. It's all plastic so the tabs might be broken off as well. I'll try and post some pictures tomorrow.
KubotaL185DT
May 6, 2010
81
Northern Calif
Pictures would be great, Thank you very much
russell.still.5
197
Lafayette, Alabama
I forgot to take pictures but here is a parts breakdown. Look at #70 & #80. The screw will be "outside" the fire wall under the hood.
KubotaL185DT
May 6, 2010
81
Northern Calif
Thank you I will let you know what I find..
KubotaL185DT
May 6, 2010
81
Northern Calif
Not looking forward to tackling this job, I am going to do as much research as I can before tearing into it. I can't see myself getting up under the rear hood housing as just ain't any room and at my age I just am not that flexible. I would appreciate any other suggestions. I have a shop manual didn't see anything that helped in it I will look through it again.
Bill
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
689
299
Herald Calif.
Hello Bill
Just wondering what part of Northern California you're in. I don't see many post from fellow Northern Californians.
Lance
007kubotaguy
Dec 23, 2012
689
299
Herald Calif.
Hello
Yes I did. Did you get a response from me. It sounds like you did not. I'm sorry. I'll send it again. Thank you Lance
KubotaL185DT
May 6, 2010
81
Northern Calif
It appears from the lack of response to this thread this is a rare issue ( I thank Russell for his help) Any suggestion as where I can get more help with this problem I have with this Dash Separation ? Thanks Bill
KubotaL185DT
May 6, 2010
81
Northern Calif
I was working in a very dusty environment, So I did a down and dirty in the field temp fix. Pictures Before with the large gap & after the temp fix
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
Looks similar to the job I did on the vacuum cleaner hose yesterday. Started out thinking I would take the head off and just shorten the hose a few inches but half way into taking it apart realized the wiring ran inside the spiral support coil, and cutting out a section would require rewiring the connectors etc. Decided duct tape would do. :D
KubotaL185DT
May 6, 2010
81
Northern Calif
I am always wrapping a crack in my wife's Vacuum Cleaner, I use electrical tape on it too.
