(CLOSED THREAD) B7100 parts
Status
Not open for further replies.
Nisp05
NJ
Selling all parts from my b7100 hst tractor. Everything in good working order except for crack in cylinder head. Let me know what you need.
fender76
B7100HST
May 24, 2017
72
Missouri
Re: B7100 parts
Hopefully this attachment worked. Looking for the small (app.) 2" flasher. Left & right are the same. Roger
GDT's Kubota
B1550HST, MMM, Frt Blade
Dec 12, 2012
York, PA, USA
Re: B7100 parts
Is this tractor the late model design? I have a B1550 which is similar to the later model B7100. I am looking for the differential case.
Sent from my SM-G930U using Tapatalk
des57
14
feeding hills,mass. usa
Re: B7100 parts
Do you have the hydraulic divert block w/ the two threaded ports, the block is on the smaller hyd steel line coming from your hyd pump to 3ph valve, Thanks
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
564
169
Herald Calif.
Re: B7100 parts
Hello
I have the adapter block you're looking for. If you don't find one send me a PM.
Thank you Lance
crippler
KUBOTA Bx23s, KUBOTA B6200, KUBOTA B7400, KUBOTA B7800, Mitsubishi D1500 II
May 25, 2014
Carthage NY
Re: B7100 parts
still have it ? want to sell the whole tractor ?
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Re: B7100 parts
esp. on old sale threads..... take a moment to look when the last time the member/seller was here..... and how many times before that they were here. This info available when you click on their username. This info gives HUGE clue on if they will ever see a post if you left one.
This particular fellow has not been back since dec. 2017 and only ever posted 5 times....... which were all responses inside this thread a year back. My guess is this thread is dead end now thus I am going to CLOSE it
Status
