coachgeo
To avoid hijacking my own install thread I pulled out from it this research into part #'s. While it is mostly about searching for parts to fit into push in freeze plug heaters... there is some relevance to the screw in types (share many parts)
For the older L and others models with a NON THREADED 32mm freeze plug on the Kubota engine. A 32mm freeze plug insert with 3/4 FNPT threads for a block heater is available we can potentially use to make our own heater unit via press in bushing w/threads inside it to insert a screw in heating element (Tisco Part #11461B)
https://tiscoparts.com/part-categories/engine/external/heater/ge11461b.html
GE360 is part# for the heating element portion appears this same part is used on some kubota's as ithe element that fits inside a screw in bushing.
