Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 12-02-2019   #1
Palominofarmer
1st Yr. Apprentice
Equipment: Kubota M7040
Default M7040 No power to dash, no start
Ok guys, time to do that last thing men do...ask for help.
I have a 2011 M7040. A couple weeks ago the tractor would not start, had no power to dash. I charged up the battery, no help. Next day I walk out thinking I'm going to dig into this thing, starts right up like normal. Finished my chores, turned tractor off, wont start again. Ran a test light to the key switch and I'm showing power but when the key is turned to start the power doesn't transfer to any other wire. Has to be switch right? No. Ordered brand new switch from kubota, installed and the damn thing cranks right up. problem solved? Nope. I started it this morning with no problem, tried to start this evening and back to square one. All fuses look good and basically the damn thing starts whenever it wants. The light comes on with door open so I'm definitely getting power to the cab. I'm not sure where to go from here. Any help is appreciated. Thank you.
Palominofarmer is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-02-2019   #2
Roadworthy
3rd Yr. Apprentice
Equipment: L2501 HST
Default Re: M7040 No power to dash, no start
Clean both battery terminals inside and out. Make sure the ground side of the battery has a good clean connection to the frame of the tractor. Start with the easy really basic stuff.
Roadworthy is offline   Reply With Quote
Old 12-03-2019   #3
Tx Jim
4th Yr. Apprentice
Equipment: M7040 HDC-1
Welcome to OTT
Ditto what Roadworthy stated. Have you cleaned/tightened all four(4) battery cable connections?
Tx Jim is offline   Reply With Quote
Old 12-03-2019   #4
Master Tech
Equipment: M7040, Nuffield 465
I have attached the wiring diagram for the start circuit and the troubleshooting chart.
Start with Roadworthy's suggestion.
In the start circuit there is a 5 amp fuse, start relay, neutral safety switch on shuttle shift, pto safety relay, and lastly pto switch.
After cleaning the battery connections, my next step would be to jump the starter to make certain the most basic component is working.
If you do not know how to do the starter jumping safely please ask first.
Dave_eng is online now   Reply With Quote
Old 12-03-2019   #5
leveraddict
1st Yr. Apprentice
Equipment: 2017 BX23S 60 Landpride box blade 54" belly mower 60" County line back blade
I had a similar experience! The plug going to the starter that snaps together was still snapped together but had some back and forth play! Just enough to disconnect but still snapped together! Thats one sloppy plug on my BX! Lucky I found it just before the dealer was about to pick it up! I still had power to the dash though.
leveraddict is offline   Reply With Quote
Old 12-03-2019   #6
Palominofarmer
1st Yr. Apprentice
Cleaned all battery terminals, checked all ground connections. All fuses look good, I even pulled out ever single one and cleaned all contact points. I had the issue with the PTO switch before but it didn't prevent power to the dash lights. Imagine turning the key as if the battery was completely dead but the battery is fine. The couple of rare times it decided to start it started very strong with no hesitation. It started yesterday but I didn't move the tractor at all, didn't change gears or even sit in the seat. I cranked it, let it run for a bit and shut it off. Later that evening there was no power again but I have the cab light come on.
Old 12-03-2019   #7
Master Tech
Quote:
A few questions so I can better understand.
When the tractor is unresponsive are you saying the only thing to work is the cab dome light? The upper front and back lights wont work? The headlights wont work? Radio wont work?
Is there power in the cigarette lighten socket?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2020, vBulletin Solutions Inc.
