PTO Shaft Safety Cover Problems
Eesquibel
L2501 Hst
May 8, 2020
46
New Mexico
On my new Tarter Rotary Cutter I can’t seem to keep the safety collar locked in on the shaft safety sleeve. Once I start cutting it comes loose right away and works itself down the shaft leaving the yoke exposed. Anyone have any tricks or fixes for this problem? I’m tempted to run it without the safety sleeve because it’s being a real PITA
Roadworthy
L2501 HST
Aug 17, 2019
1,649
525
Benton City, WA
I'm not sure I understand the question. My plastic PTO shaft cover has buttons that hold the end in place. It's a challenge to slip it back once the buttons slip into place. There are chains on each end to secure it - one to the mower, one to the tractor. The sleeve doesn't spin, only the shaft. The collar should not permit the end hood to easily slip back on the sleeve.
Eesquibel
L2501 Hst
May 8, 2020
46
New Mexico
Sorry I'm new to the game and not familiar with the proper terminology. I guess I'm referring to the "end hood" I cant the the one on the tractor side to stay in place. Mine are tabs that have to be depressed with a screw driver.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
525
Benton City, WA
If you get the little tabs aligned with their respective holes they should pop into place kind of making the collar and tube act as one piece. Once in place they are usually somewhat difficult to depress to slide the collar back. Good luck.
avvidclif
BX2230 L285
May 12, 2020
23
Mabank, Tx
Mine got accidentally thrown away about the third time I was trying to hook up and that sleeve wasn't co-operating.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,128
933
Williamstown Ontario Canada
Tarter's web site is no help.
Their parts breakdown shows the pto shaft as one item complete with cover, no breakdown.
Any brand name on the pto cover?
Post some pictures.
Dave
4,390
Did you find replacements or are you operating it without them?
I think when Avvidclif said, "Mine got accidentally thrown away about the third time I was trying to hook up and that sleeve wasn't co-operating." he wasn't interested in finding a replacement, because he discarded it because of his frustration! But I could be wrong.:D
avvidclif
BX2230 L285
May 12, 2020
23
Mabank, Tx
You would be correct.
SidecarFlip
Banned
546
You get entangled in that shaft, you'll wish it was there... If and I say if, you survive it. Go buy a new drive shaft with the shields and use it, unless of course you feel you are invincible. Lots of people (farmers and others) have and lots of people lost fingers, arms, hair and lives.
Been farming for 40 years now and my pto shafts are always covered and safety chained. No exceptions. I still have all my parts and I equate that to the covered shafting.
Even a small tractor has plenty enough power to give you a very, very bad day and it only takes a split second to become an amputee or worse.
quazz
L3800 and Z411
Jan 6, 2014
296
Rockley, NS
Very true and a great reminder but damn chilling. I will triple check everything next time. Thanks.
