HST Pedal Damper
NickAdams
B-2400 HSD
Jan 11, 2021
61
22
I noticed that the pedal damper was disconnected - appears that the clip fell off. When trying to replace it, I fully depressed the pedal but the damper did not quite line up with the hole. My instinct was to bang it in with a hammer - but thought better of it. One thing that concerned me is that to get it close (as shown in the picture) the pedal was fully depressed- maybe not good - maybe good?
I reviewed the shop manual re checking and adjusting the neutral but the pin is so close I think I am missing something. The pictures in the manual are not clear (very grainy), so it is hard to see what should be done. Hopefully, a simple solution? Bang it in with a hammer?
Your help is appreciated.
Dustball
2016 B2650HSDC
Sep 15, 2023
492
355
Hudson, WI
Is the damper functional? It should extend and retract smoothly but with even resistance throughout. The damper is not a spring. It adds resistance to the pedal motion but should not stop it from returning to center.
NickAdams
B-2400 HSD
Jan 11, 2021
61
22
So I should be able to pull it a longer and compress it shorter? Did not feel like it's pliable but I'll see today. If I can pull it a little longer - should I push the pin the hole and clip it in?
Dustball
2016 B2650HSDC
Sep 15, 2023
492
355
Hudson, WI
Yes, you should be able to move it by hand but there will be resistance. The pedal arm is what extends/retracts the damper, not the other way around. The damper will stay wherever it is if it's disconnected as there is no internal force to extend or retract it.
But I should say this- without the damper connected, the pedal should return back to center on its own.
7,403
Maybe you're just not getting it lined up since it's in a close area. Might use a bench grinder to form a slight (smooth champher) taper on the end of the pin to allow it to line up easier.
NickAdams
B-2400 HSD
Jan 11, 2021
61
22
Turns out its really bent - does not retract. Trying to source a used one - new one at Messicks = ~$200. Yes - tractor runs fine without it. Thanks.
