Mount a FEL on a L245DT
Greg Maine
L245DT
Feb 4, 2022
maine
I have a L245DT, and I want to mount a loader on it. How are they mounted on the tractor? I have seen photos, but they rarely show mounting brackets. If I find a loader, I will need to insure I have the correct mounting brackets. Thank You
3,353
I think you are looking at a significant fabrication project. A loader with the proper OEM brackets will be hard to come by. Here is the B1730 loader attaching kit parts diagram for the L245DT tractor. There are five attachment points boxed in red:
  1. Front of frame
  2. Left side of frame
  3. Right side of frame
  4. Left rear axle housing
  5. Right rear axle housing
Greg Maine
L245DT
Feb 4, 2022
maine
  1. Front of frame
thank you this is what I was looking for
Greg Maine
L245DT
Feb 4, 2022
maine
  1. Front of frame
Thank you this is perfect
4,391
Greg, if you look closely at the side of your transmission you'll find some tapped holes. They may have a plastic plugs still in them, or filled with mud if no plug is there. Those are the frame mounting points. Those will tell you how to fabricate everything on the side to determine where the loader tower bottoms fit.
There are also some tapped holes on the bottom of the transmission that are in line with the side holes. These holes will anchor the steel connecting the side pieces the towers set in.
When the side and underneath frame is finished and attached you can determine the length of the bars that go from the bottom of the towers to the rear axle. These are critical for support so don't overlook them.
A few years back I bought a 5' bucket and loader from a guy in Arkansas and fabricated the entire mounting hardware for an L305. If you do a search on here you may find some pictures. If you'd like more details let me know.
Most critical information before starting is to know the width of your tractor and compare that to in inside dimension of the loader arms. IT HAS TO FIT. Have fun.
Greg Maine
L245DT
Feb 4, 2022
maine
Thank you. I do love a challenge and I have lots of patience.
4,391
All the bolts will be metric, and have to be a specific length. I bought them all at Fastenal and were over $125 back then.
