Help ID my KX-30
SiSi
KX30
Dec 12, 2013
BC, Canada
If I did it right you should be seeing 2 pictures of the rx301?.
I was looking at the serial # : 10293 Does anyone know where I can find a parts catalog/manual for it. What is the Canadian/American counterpart model. Thank you for your help
11,276
I did a ton of research and I only came up with one Japanese site that said one little peep about the fuel filter and that was it!
I does appear to be a very rare and odd model.
I think your going to have to go to plan 2:
What is wrong with it, or what do you need to know, or what parts do you need.
I'm pretty good at finding like parts that were also used on different models, so I might be able to help you find parts.
It's a Kubota, so it will work just like any other Kubota, they all follow certain rules, and operating concepts.
Start throwing out questions and you'll get answers.
3,581
Sorry I can't be of any help, but I gotta say that boom setup is wild! Never seen anything like that.
11,276
That serial # comes up with KX121-2 and KX71-3 and about 200 other tractors and mowers (normal for Kubota, they recycle serial #'s) but no mention of your model (that's not unusual for gray/grey market).
How big is the motor in it? 2,3,4 cylinder can you see the size of it, should be cast in the side of the block behind the fuel injector pump side.
SiSi
KX30
Dec 12, 2013
BC, Canada
-In the photo you can see It is a 4-clyinder diesel and you can see the 0618n stamped in the casting behind the oil filter (unscrewed for the photo). All the controls are on the front on a panel. It says Kubota "Ace Gear" what-ever that means? The only model I have seen that comes close is the RX301 (which I believe is also a gray market model) Hope this helps.
-It came to me with no thermostat in it and presently does not have one. I believe it should have one, any ideas of which one would fit...or if it even should have one?
SiSi
KX30
Dec 12, 2013
BC, Canada
I don't seem to be able to see any more numbers on it. Anyone have any idea what size and model the motor is?
Thanks
