Replacement Headlights B7100
phaser
B7100HST 4x4, FEL, field mower
Aug 6, 2013
171
Oregon
I need to replace the stock headlights, and my local dealer wants $156 for a pair. :eek:
Can anyone point me to a cheaper source OR a plug and play LED set that would fit without any modifications?
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
phaser
Aug 6, 2013
171
Oregon
Thanks Sam, that's an excellent alternative, and I like the way you secured the lights with the large O-rings as well. Thanks for the link too.
9,483
I just used a could flat pieces of steel (could use aluminum) and drilled holes in them fit in the lights, then bolted in place.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
just a quick one chaps, early B8200 models (round headlamps) use the same lamp assembly as B5100/6100/7100 models.
if you find an old B8200 with good lamps, grab them quick.....;)
so do early B6200 & 7200, if you can find one that is.
rob
tmessenger
B7100D P
Feb 17, 2013
40
Fairfield, IA
Be aware that the 7100 alternator only puts out about 130w with the engine up to speed. I would size the lights for 90w or less so you still have juice left (round 3.3A @ 12v) to recharge the battery.
