KUBOTA Serial numbers
John Clement
Kubota L22o1DT
Nov 11, 2013
Australia
New to this website. Just bought a grey import KUBOTA L2201DT. Good machine.
Serial number on "chassis" L2201DT-51404
Number on engine 1101-09608
Can anyone interpret production date from these details please?
Thanks John Clement
8,772
Bratwurzt,
Where the (blank) did you come up with that info???????????????????????:rolleyes:
The serial # tells us it's a model L2201DT with a serial # of 51404
John,
Sadly there is no way to be able to tell the year from the serial #
The best you can hope for is that someone else bought their tractor new and they can tell you by their Serial # if it is older or newer than theirs.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
On the serial number front, i also suspected that it is not possible to find out the age of a specific kubota tractor by that number,but,
after a recent conversation with a good freind at Kubota, it does appear that it is possible to date very closely the age and production date of a specific model via the serieal number, and thats from an official source.;)
rob
SiSi
KX30
Dec 12, 2013
BC, Canada
Re: KUBOTA Serial numbers 862010293
hi kubota ser 862010293 excavator is it a kx30 cant find a kx30
ser is right it is on machine thank si
8,772
SISI,
I did as much research as I could and can't find anything on it. 1: Are you sure it's a KX30 model and not a KX030? 2: The serial #'s of Kubota's are normally 5 digits and no more, look for other # plates or where your getting the # does it say "serial #"? 3: Pictures would really help with some details.
Bratwurzt,
No problem at all, Just had to bust your chops... Hum Rye... Yummy
freewheel3
Mar 9, 2013
333
34
Alberta
Thanks John Clement
If you look on your back rims you will find a date stamped on them. Although this won't tell you exactly when your tractor was built, it will give you a pretty good idea. As long as they are original to your tractor, that is.
SiSi
KX30
Dec 12, 2013
BC, Canada
SISI,
Bratwurzt,
Thank you for your help. If I did it right you should be seeing 2 pic of the KX-30
I was looking at the serial # again and it looks to be : 862 - 017293
