I have an L3200DT. I put a Westendorf frontloader on it. Loader attaches to the axillary hydraulic block with three hoses, marked by Kubota as in, out, and tank port.
I am purchasing a three-point hitch log splitter that will also run off of the axillary hydraulic block, and I will disconnect the loader and connect the splitter with quick-connect fittings. It appears the splitter only uses two hoses: in and out.
1) I don't understand what this "tank port" is all about.
2) Should I disconnect the "tank port" line from the loader when running the splitter?
thanks
thanks
