Good Morning,
I was having problems with my three point hitch being erratic (jumping up and down when I operate the FEL) and dropping under weight. I replaced the rings on my hydro piston and now looking to inspect/repair the control valve for worn linkage/spring pins and relief valves-etc..
It appears it would be easiest to pull the entire unit off the tractor to do it thoroughly. Is this the correct assumption? Also. Any advice would be appreciated.
Thanks!
Thanks!
