Front mount flail mower from mid PTO
11,303
Not being picky, just don't want it coming unglued on you.
And maybe add a couple gusets off the sides of those supports?
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
834
1,553
Paul Allwood
Jul 8, 2025
834
1,553
Finished welding a few bits then re-fitted the rear roller today. I also shortened the links between the tractor and the mower by about 300 mm to get it closer to the front of the tractor - hoping that this, along with the rounded ends on the rear roller, would help the steering uphill.
I had also made some other changes to allow it to drop a further 20 mm closer to the ground as the first cut was just a little long.
These links are still temporary - enough so I can use it to mow our grass. I think I'll make a lifting setup so I can use it with the loader removed.
I started mowing and the cut height was better, having it closer to the front of the tractor was better for maneuverability, but it didn't really help the steering uphill. The only thing that helped here was lifting the weight off the rear roller, then it steered like the mower wasn't there.
I tried it on some light green waste that we had pulled out of the garden and it mowed over it and mulched it like it wasn't there.
Here's what I tested it on....
Sorry the video isn't great - best I could do from the drivers seat....
Pretty happy with how it works overall.
I'm curious - does anyone here use a front mounted flail mower with a rear roller ? If so, does it affect your steering as much as mine does ?
4,038
2,489
Maybe you could incorporate some spring into the lift arrangement to the loader to take some of the weight off?
If you go with a separate lift, you could include an accumulator deal to keep some pressure on the lift cylinder.
Paul Allwood
Jul 8, 2025
834
1,553
I am thinking of some sort of a separate lift that includes a spring so it can take some weight but still move with the ground.
Interested in the accumulator idea too.
Thanks.
Paul Allwood
Jul 8, 2025
834
1,553
To improve the steering without taking the weight off the rear roller, I could possibly replace the roller with caster wheels since they seem to be working really well at the front. Maybe then I could move the roller in closer to the cutter drum and up a little so it still helps prevent scalping, but let the mower mostly ride on the wheels.
Another idea that's got me thinking is to incorporate the design of omni-directional wheels into a long roller so it can roll in any direction - back and forwards, side to side - so the tractor doesn't have to push the roller sideways. Like these....
No idea of I could size and make them so they would fit and survive at the back of a flail mower. Probably too many moving bits for things to get stuck in.
I like to think about dumb ideas sometimes - it helps make my less dumb ideas seem better.
Yeah, more caster wheels might be a better plan.
Still interested in others' experience if you've used a flail at the front of your tractor.
Paul Allwood
Jul 8, 2025
834
1,553
I found a spot of longer grass outside our place to test it yesterday. Pretty happy with how it cuts.
Chanceywd
Mar 26, 2021
880
871
central ny
Looking like it does a nice job cutting, Paul.
Bill
Paul Allwood
Jul 8, 2025
834
1,553
Bill
Thanks Bill. Yes, I'm happy with how it cuts. For our lawn area the finish is plenty good enough for us, but I had to set it so low that the tips of the Y flail blades are quite close to the ground. Then even with the rear roller it skinned some dirt off a high spot where the ground wasn't very uneven.
I'm also pretty happy that with a cutting width of 55", it doesn't seem to strain the tractor, and that's with only 14 HP at the PTO.
For our grass I think a duckfoot blade as shown below would be better. Might try this on the MKII cutter drum.
3,165
Thinking more about the turning problem you have and wanting to remove the loader (which eliminates the ability to lift the front mounted mower in your current configuration).
Since you have hydraulics and a welder and are clever…
Can you come up with some hydraulic cylinder that lifts the rear of the mower as you need to turn? I am not sure how the hydraulic steering system (that you are adding ) works but perhaps you could use it to lift and lower the mower as you turn and lower it as you straighten out the turn.
This may be way too complicated to be reliable though???
Paul Allwood
Jul 8, 2025
834
1,553
Thanks for the vote of confidence, Russell. I guess anything can be done but not sure I'm clever enough to make that happen automatically.
I am planning on incorporating a lift mechanism into the front hitch to make it operate more like others I've seen online. This is mainly so I can use the mower without the loader for better visibility - it's ok now, but I think better without the loader. Another benefit might be that I'll limit the lift range to prevent inadvertent drive shaft damage - something I need to be careful with while using the loader to provide the lift. I'm thinking that something spring loaded might help too.
I've started on the hydraulic steering to make sure I stay clear of the new steering pump and hoses when I do build the front hitch/lift setup.
Paul Allwood
Jul 8, 2025
834
1,553
I've been thinking about caster wheels vs rear rollers for my flail mower.
I had a look at Landpride finish mowers that have 4 caster wheels - 1 at each corner. No roller. The 84" model weighs 812 lb.
Pretty heavy, but the 4 casters must work even with this weight.
There would be as much need to prevent a finish mower from scalping as a flail mower, but I wouldn't expect the 4 casters to do as good a job at anti-scalping as 2 casters and a full width roller.
So I'm wondering if one of the reasons for the difference is more the anticipated use. A flail mower might normally be expected to be able to handle rougher ground than a finish mower, hence the use of a rear roller on the flail for better rough ground anti-scalping performance compared to just 4 casters.
Just a thought.
I've got four 8.5" OD wheels on the way. I'll use these to make 4 casters to go across the back of the flail mower and report back.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
437
332
NH
I have a Landpride FDR2584 and it works great with the four wheels. This is why I asked in a different post why a flail mower couldn't work the same way.
I have anti scalping wheels on the front of my finish mower and although my fields are relatively flat there are some bumps and humps and it does fine.
I do agree that the flail mower is intended for rougher ground, but they do offer a blade instead of hammer cutters for a better cut like a finish mower. I would think that would be for less rough ground.
4,038
2,489
I think you would want any anti-scalp device on the front, not the rear, so it would hit the bump before the blade got there.
imarobot
Apr 18, 2025
437
332
NH
That's where they are on my finish mower
imarobot
Apr 18, 2025
437
332
NH
Are you referring to small anti-scalp rollers ?
Yes.
I'll have to take a look at mine, I have the mower packed away for the winter, expecting snow this weekend. I thought there were two, but from looking at the parts manual there is only one roller 10" x 4".
