biketopia
Feb 15, 2024
448
483
Warrenton VA
I have the 2 cords I bought stacked on the south side of my garage in the sun and it's ready to burn now.
Moving another 2 cords I cut up on my porch now. Should be good until beginning of March with this. Have about 20 more face cords of ash in the woods I am cutting now. Just bought the bigger Milwaukee 20 inch battery saw to try and I love it. No more gas required.
Looking good. By my rudimentary math, I should have around 5 and a half to almost 6 cords split and stacked on hand. Last year we went through about 4+, and I only needed a small top-off of the propane tank from its initial summer fill. And that was more playing it safe with a big snowstorm coming, in case I had to be away from the house for a while helping at work.
What stove do you have? I run an older Fisher insert. Works great and will eat a 30" log, but it's a hungry stove. Thinking of changing it out next year to a Jotul. I also miss not being able to see the fire like I could in the fireplace.
I love my Milwaukee battery tools, I have the original M18 saw, thinking of picking up the new one too. I still use gas saws here and there, but always been impressed with the M18 stuff.
biketopia
Feb 15, 2024
448
483
Warrenton VA
Yep, and today is the day. Snowblower won’t go on just yet. Chains will go on next week or two. Do some service, motor oil change, etc.
if you’ve ever put tire chains on in the snow or really cold weather, you know why I put them on early. Much easier when it’s 50-60 degrees F. 🤔
I still have almost two months of cutting left here. I'll be putting the chute blocker and mulching blades on the Scag in the next week or so. Leaves are just starting to change, the Dogwoods are falling. The acorns are dropping like crazy, though.
Sidekick
Jul 29, 2023
1,294
1,891
N.Y,
We have an old Jotul Oslo that has heated our house for about 15 years. No pollution stuff on it and basically been trouble free. Really nice having the window. Only time it has struggled is with the 20 below windchills in February because our great room is surrounded in large glass windows that have lost their seals. We are still on the same 250 gallon tank of fuel oil down to almost half from when was last filled the year the woodstove was installed. Home Depot has a good deal of the day again today on the saw 🤔.
7,373
Yeah, mowing season is longer for some.
I don’t like to get behind with tractor, pellet stove, etc.
L35
Jun 13, 2010
724
837
CT
I’m always using the L for something, but actually remembered to take a quick shot today. Moving the lift around the property for different projects.
johnjk
Apr 13, 2017
1,822
2,248
West Mansfield, OH
Got out and mowed today since we are possibly getting rain from the storm remnants Sunday. Grabbed a stick, set the tunes to 70’s rock and was able to get the entire yard done. First time since July it was dry enough. Now time to trim back all the trees along my trails.
JonM
Nov 29, 2024
294
708
wisconsin
finished my new pasture today. yes the corner post was bent the part in the ground is straight to the hole.
Reactions: 10 users
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
837
1,557
Some more time using the tractor today rather than making bits for it. We call it a rotary hoe, most of you call it a tiller....anyway, I put this heavy green thing behind the tractor to get some areas ready for planting. Hopefully it will end up looking more like garden and less like dirt.
I'm still amazed at what can be done with this small tractor.
The blades are quite worn, but it still seems to work pretty well.
Reactions: 10 users
mdhughes
L3901DT
Dec 10, 2014
1,484
1,594
Ste Geneveive county, MO
Used the L3901DT yesterday to do some really heavy lifting. Put four 40# of salt from the back of the truck and took it around to the basement overhead door. At least it was some seat time on the tractor.
Reactions: 6 users
ken erickson
Nov 21, 2010
1,447
2,719
Waupaca Wisconsin
I have started my maintenance mowing on the oak savanna. Until I feel comfortable with prescribed burns this is the best I can do. It keeps the unwanted woody species from regrowth especially around the edges.
I mow high , about 8 to 10 inches , after the native grasses and forbs have gone dormant for the season.
28 acres plus to mow and in the video you can see how uneven and rough in some places. Very slow going. I can do about a acre during one session of 2 to 3 hours on the tractor.
Reactions: 6 users
3,165
Forgot to link the video???
3,165
I have the direct embedded link when I open it up, strange.
Interesting, there is just a big white blank area under the text. But I will look later when on a better internet connection. iPad may be the problem also???
Added on 10/15 on edit: The video link now shows up now. I assume it was a connection issue.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
489
565
NE Ohio
Took the loader off and put the deck boot on so that I can begin the Fall chore of vaccing up all the leaves. It's been pretty dry, so the oaks and maples are dropping their leaves earlier than usual.
ken erickson
Nov 21, 2010
1,447
2,719
Waupaca Wisconsin
Had a nice day mowing the oak savanna yesterday. It had sprinkled early morning so the dust and chaff was minimum. Cool and cloudy.
I am leaving a patchwork of mowed and non-mowed areas which should continue to give good ground cover and habitat for the critters. This view is one of the largest mowed areas I will do this fall.
It was a good day to be sitting on the Kubota! :)
Reactions: 11 users
g_man
Feb 3, 2023
413
1,955
NE Vermont
We had a very good soaking rain all day Tuesday and into Wednesday morning. Around mid-night we had a thunder storm and it absolutely poured for an hour. I have several drainage chutes/ditches cut thru the inside sod bank of this downhill curve in order to get the water off the road and into the ditch but they clogged with leaves so I was left with a washout down the road. I fixed it up with the LandPlane today. I thought I might have trouble with the leaves. I did not want to bury them in road surface gravel. But they floated to the top of the mixing gravel in the LP and caused no problem.
gg
Reactions: 9 users
mdhughes
L3901DT
Dec 10, 2014
1,484
1,594
I put the land plane on the L3901DT and worked on our shared private road for a little over 2 hours. I guess I worked on about half of the length of the road. Mainly worked on the two hills that was wash-boarded really bad. We had 1.67" of rain, but it wasn't really enough to get the road wet enough to work up good, but it is in better shape then it was. This is the first real rain we have had in close to 3 months.
Reactions: 6 users
