Kubota MX6000 Air conditioning problem
davemc
Kubota MX6000
Jan 9, 2022
14
The AC on my MX6000 stopped putting out cool air. It still blows air, but its not cool. I figured it was due to dust and debris, build up, so i blew everything out with compressed air, which has always fixed the problem before. But it didn't seem to work this time. It still blows, just not cool. I opened up the hood and took a look to see if I could see anything obviously wrong, and there is a roller to the side of the fan belt, but it doesn't make contact with the fan belt. I am not sure what it is. There is no belt on it. I will include a photo. I am not sure what normal looks like. The photo is taken from the right side.
#40Fan
672
498
Does the compressor clutch engage and turn when the A/C is commanded?
davemc
Kubota MX6000
Jan 9, 2022
14
I am not sure what the compressor clutch is or how i can tell if it engages.
davemc
Kubota MX6000
Jan 9, 2022
14
Yes belt is tight. It does not make contact with the roller in front of it, but it looks like something makes contact with the roller at least periodically from the clean area on on it.
Bee-Positive
Nov 16, 2022
1,236
1,120
Amsterdam, NY
That is the pulley tensioner, it should be adjusted ride on the belt and keep it tight. I can't tell from the parts drawing if there should be a spring holding it tight or if the bolt is tightened to hold the pully in place. The top of the belt goes around the AC Clutch Assembly.
Look at the compressor unit (the top most pully).
The pulley is turned by the belt. The center of that pully is the clutch assembly and should not be turning when the AC is off. Turn on the AC and watch the clutch (the center of the pulley highlighted in yellow), it should spin.
Bee-Positive
Nov 16, 2022
1,236
1,120
Amsterdam, NY
I didn't see the workshop manual on Kubotabooks but you should get one - maybe a member on here has one.
If the belt is tight and clutch is spinning when you turn on the AC you'll need to check if the refrigerant is low or has a leak, again the WSM should cover how to trouble shoot.
davemc
Kubota MX6000
Jan 9, 2022
14
Should the pulley tensioner be standing off from the belt, or should belt contact it?
Bee-Positive
Nov 16, 2022
1,236
1,120
Amsterdam, NY
The parts diagram shows it against the belt.
It should be in contact with the belt and checked/adjusted to kept the proper tension on the belt.
You need the WSM.
3,165
You need the WSM.
@Bee-Positive
I recall another thread about a similar pulley that turned out was just placed there to protect something from the belt (not to tension the belt).
Are you 100% positive it is for tension on this model tractor? Or are you just assuming it is from the other 99.99% of assemblies that use that type of pulley to add tension?
I have no idea either way so didn’t make the same comment about it as you did!
Bee-Positive
Nov 16, 2022
1,236
1,120
Amsterdam, NY
@Bee-Positive
I don't have the WSM so I looked up the parts diagram (posted above) for the MX6000 on K-Pad . To me it shows the pulley against the belt and I didn't see any other way of keeping the belt tension adjusted.
The name in the parts list shows it as "PULLEY,TENSION" but I suppose it could be just for protection as you say. I would hope the WSM would make it clear.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
593
259
CNY
That pulley is to stabilize the belt so that it does not fly off the compressor pulley during operation. It does not contact the belt during normal operation only when the slack side of the belt is flopping about. The tensioner is on the left side of the engine.
As mentioned verify the compressor clutch is engaging and turning the compressor shaft when the AC is on. You should be able to see the difference when turning the AC on and off. Make certain the temp control is set to cold and that the coolant valve is shut off. After that you will probably need AC gauges to diagnose further.
Bee-Positive
Nov 16, 2022
1,236
1,120
Amsterdam, NY
That makes sense - thank you.
