OK, I have to ask... why are you mowing the field ? I have farmers that pay for 6-10 acre fields near me so instead of YOU cutting grass, you could be paid and watch crops being grown and harvested.
I have a 2001 Husqvarna ZTH-6125 zero turn mower that I bought new. It is now 25 years old. My only wish is that I had bought it 10 years earlier.
The deck is adjustable from 3 to 6 inches (IIRC) and with sharp blades and the deck height set to 3 inches it will cut 12 inch high DRY grass with ease, even with its 61 inch cut. It will cut wet grass well, but not as smoothly as dry grass.
The beginning of the second season I had to replace all the hydraulic lines, as they leaked at the ferrules. Poor design on the part of Husqvarna. One coil went bad just last year, I replaced both with new Kawasaki units. Other than that, just maintenance items. The engine burns no oil.
For all but the last 3 years I cut 10 acres of grass weekly. The mower cut my time in the seat in half compared to a tractor and bush hog. Push mowing/weed eating is near zero because you can cut that close.
One bad point with zero turn mowers is when they are used on hills of any significant angle. They are fine until you have to change direction, even a little bit, and then they go like a dart, straight downhill and out of control. When I bought my zero turn I lived in NJ, where everything is flat or nearly so. Now I live in WV, where you have two choices of direction, up or down.When we bought our house on 5 acres of old cow pasture, I originally ran the B2650 with a 72" finish mower and an old, sketchy ridder. The next season i was on the hunt for a zero turn. Bought a used Scag Turf Tiger 61" cut and man....that thing does such a nice job and is sooooo much faster and nimble, I don't know why everyone doesn't use one. I can cut our 5 acres in 2 hours or less most days, unless it's early spring when the grass is thick and wet.
Agree, and will add that a zero-turn has limited additional usefulness… when compared to other, more universally-capable equipment. The money spent on zero-turn may be better spent on equipment that can accomplish additional-work zero-turns can never.How much seat time do you want. The Zero turn fanboys will push them without even looking at the quantity of mowing you have to do. With 10 acres once a week, I would want something way bigger than a small zero turn because I don’t want to spend unlimited hours mowing. If the 10 acres is mostly open with little obstacles, find a 10-12’ mower. If you are only looking for a tractor to run the mower and not do anything else, go find a good used tractor of any brand. If it’s flatish ground, a 2wd will work fine and have better turning.
I mowed the same 10 acre property with a 6 foot Woods brush hog and a Ford 1920 tractor and my 6125 Husqvarna zero turn.How much seat time do you want. The Zero turn fanboys will push them without even looking at the quantity of mowing you have to do. With 10 acres once a week, I would want something way bigger than a small zero turn because I don’t want to spend unlimited hours mowing. If the 10 acres is mostly open with little obstacles, find a 10-12’ mower. If you are only looking for a tractor to run the mower and not do anything else, go find a good used tractor of any brand. If it’s flatish ground, a 2wd will work fine and have better turning.
That is a good solution...if you don't mind the smell and upkeep of the cows.Have to ask… why are all of you spending so much time and money mowing.
I have 15 acres, and HAD a 100 hp tractor and a 16’ bat wing. Which really struggled because the grass was so thick by the way.
One day when I was mowing I said why am I doing this.
Sold the tractor, put up a fence and got some cows, now I don’t mow. Don’t want cows, get goats, sheep etc. Free meat and $$ from selling calves, plus ag exemption on land saves $ on taxes.
You don’t want to fool with cows, there are people who will rent ground and put their cows there.
Just an option.
Well ... I'm gone for weeks at a time, and don't like people on my property, so no renting ... Or critters running wild on there own.Have to ask… why are all of you spending so much time and money mowing.
Just an option.
Yep, everyone gets to solve their own situations. Different ages, different personalities, different circumstances all get different solutions.Well ... I'm gone for weeks at a time, and don't like people on my property, so no renting ... Or critters running wild on there own.
I just cut my 14 acres of fields and 1.5 acres of lawn ... Tractor and rear finish mower do the fields, Z-turn does around the house and the ditch my bigger CUT can't do ...
Critters can be the answer for some, and for others a tractor answers the question!
You forgot to include the vet bills for the sheep. While not the same animal, in 1985 I totaled the yearly cost for my wife's horse (hay, grain, salt block, vet visits, worming paste, farrier cost and I discovered it cost more in that year than if I paid for the hospital bill for my daughter born in that same year out of my pocket.I "may" decide to try a few sheep once I retire ... But no way I want enough to be able to eat down my 16 acres of grass, and they really need to do "rotational grazing" so more fencing, and you gotta still cut the grass when they are in a different area ... Then I'd need to find a buyer, and probably would change my tax situation, plus state reporting of selling critters to eat ... Record keeping ... Water, feed for winter, where am I gonna store that hay? Do I make hay myself, and buy more equipment, or buy the hay?
Or ... Just dump some diesel in the tractor once in awhile ... It sits until I want it, the coyotes don't bother it either!
As you will know, it's not fair to compare cost of horse up keet to any other animal !!! I lcna keep a herd of cattle at less cost then a horse.You forgot to include the vet bills for the sheep. While not the same animal, in 1985 I totaled the yearly cost for my wife's horse (hay, grain, salt block, vet visits, worming paste, farrier cost and I discovered it cost more in that year than if I paid for the hospital bill for my daughter born in that same year out of my pocket.
Union or non union cows?I got lost somewhere along the way ... How many cows are needed to run the bat wing?![]()
