5,691
I aint done nuttin still figuring out how to the the FEL off the damn floor
g_man
Feb 3, 2023
410
1,931
NE Vermont
Perhaps you should have contacted the Historical Society about digging at the depression, it may be a grave.
That's a good thought but I am pretty sure it was a log. When we first came here after a few years a couple logs were pushed up by the frost and I dug them out. This was previously a log landing and I am thinking that when they cleaned it up and graded it off some stuff got buried.
gg
5,691
I think we need a picture of this so we can help you figure it out.
I am limited on space but I think I will try the boom on the bx and see how much I can lift it and then block it up untill I can get it to the hight I need, then move the B in place and see if I mess something else up,,lol
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,749
4,632
PEI Canada
Mowed and then cleaned the deck of the mower. Probably one mow left before things stop growing.
Sidekick
Jul 29, 2023
1,287
1,866
N.Y,
Loaded it up with firewood. Hundreds of standing dead cherry and fallen ash trees to deal with. Pre-seasoned firewood 😄. Love those battery saws and charging them with solar so free wood if you don't count the $48 dollars of diesel in the rtv 😳.
20260925_150703.jpg 20260925_150722.jpg 20260925_150926.jpg 20260925_152112.jpg
Reactions: 16 users
g_man
Feb 3, 2023
410
1,931
NE Vermont
View attachment 179647 View attachment 179646 View attachment 179645 View attachment 179644
I am interested in those battery saws. I used to think they were to good to be true and must be toys. But I am changing my mind after seeing a bunch of comments like yours. About how many cuts can you make on wood like you have piled on your ATV can you make on one charge ? Thanks. BTW - Nice neat wood pile you have made !!
gg
Sidekick
Jul 29, 2023
1,287
1,866
N.Y,
gg
I use mine for anything 12 inches and down.cuts depend on battery size and wood type. A 12ah battery with a sharp chain will last as long as a tank of gas on my small echo saw. A 8 ah battery is lighter but less torque for the saw with shorter life. They're not toys. I tried the Dewalt saw first and that was a real piece of junk compared to the Milwaukee. Bad vibration and just wasn't comfortable to use. There's also better brands available for a price. I switched to all battery outdoor power equipment because my wife has chemical sensitivity syndrome and I had to remove my clothes on the way into the house because the residual 2 stroke fumes outgassing from clothes would choke her up making it very hard to breathe. Biggest downside is batteries don't last long. High amp draw and cheap BMSs tend to kill them right after 5 year the warranty runs out. I just had 2 12ah $300 each batteries die at a little over 5 years. For me it is worth it though. For occasion use I have heard that Harbor Freight has a very affordable one that's supposed to work good.
Here's an old video showing how they cut
g_man
Feb 3, 2023
410
1,931
NE Vermont
Thank you for the info @Sidekick. You covered it very well. I would not have thought to ask about battery life or cost. The newer battery equipment is amazing.
gg
Sidekick
Jul 29, 2023
1,287
1,866
N.Y,
gg
Yes it is so nice to just pull the trigger and have it run. Plus you don't need to carry a can of premix into the woods. Biggest part is keep your chains sharp for longest battery life and don't force them to try and cut faster as that will shorten battery life. You still need a big gas saw for large stuff also.
BT3101
L3130 GST, FEL, TaylorWay BH W/Subfr Rotary Cutter, Pallet Forks, Grapple Bucket
Mar 20, 2016
96
188
Evansville, IN, USA
Anywhere you can stand it up vertically? May need to weld a chain hook to one side of the bucket. You could probably get a couple of the Harbor Freight moving dollies or build a tubing frame to roll it around on.
S-G-R
Jun 17, 2020
1,749
4,632
PEI Canada
Moved the deck stairs out to drill a few post holes.
Reactions: 7 users
johnjk
Apr 13, 2017
1,820
2,240
West Mansfield, OH
Broke out the B3200 and did some prep to drop some standing dead ash. Needed to get the invasive roses and olives out so I can get to them with a chainsaw. One of these days I’m gonna rent a skid steer with a brush head and make it an easier process than backing up with the brush hog. Now I can wait for it to dry up a bit more and not worry about dry seeds blocking the intake. IMG_7124.jpeg IMG_7125.jpeg IMG_7126.jpeg IMG_7127.jpeg IMG_7128.jpeg
Reactions: 8 users
GrumpyFarmer
5,247
Good day.
well this morning starting out in the crapper…the big girl was dead as a brick😢. As it turns out my battery disconnect is either corroded or no workee. I did some Agri-engineering and was able to essentially jump the disconnect with the two short leads so the battery could be grounded….And away we went.
so we played in the woods and I shuttled some logs then cut to length and loaded in trailer to take them for a drive in the morning.
when I went to use the hydraulic top link to disconnect the logging winch I sprung a leak…tightened that up and away I went again.
put the rear mower on and cut the pollinator habitat down per the schedule and then mowed pasture and cleaned up storm debris. But not before I did a regen (worked right thru it) and then I needed to blow the chaff off as big girl was getting hot.
it’s beer thirty now. 🍻
Reactions: 14 users
Bmyers
May 27, 2019
3,642
4,957
Southern Illinois
Spent yesterday getting odd jobs done. Aligned the new connex my wife got with the one we already had, worked in the chicken coop, added wifi extender, and other various projects.
One of the projects was to get the Massey Fergusons out for their monthly start up. My wife had never operated any of them, so I got her on the MF383 and her take it down the field road.
Reactions: 12 users
forky
Feb 23, 2021
352
395
Wisconsin
In regard to the discussion on electric saws, I have the Makita XLT 36 volt saw with 14" bar.
While I do like it for quick tasks or as a saw in my side x side for clearing wind falls across trails
or limbing work, it can never replace the real power of gas saws. Gas saws have more chain rpm's and more torque hands down. The only heat I have is wood and gas saws are a must for the real wood cutting jobs.
I like my battery saw for easy work loads only.
Sidekick
Jul 29, 2023
1,287
1,866
N.Y,
I cut between 12 and 18 face cords a year to heat our house totally with wood. 97% of it is cut with battery saws now. I'm looking at that new big husky electric saw now to ditch the gas totally. Just so reliable and trouble free to me.
GrumpyFarmer
5,247
If that was all it took for my wife to ask me to take my clothes off, I’d be using 2 stroke fuel for cologne.🤠
Wise cracks, aside how do you holster your saw on the machine? I like the scabbards on the loader frame but I suspect tree branches / limbs maybe not my friend. I’d like to find a solution inside the operator station or off the rops
johnjk
Apr 13, 2017
1,820
2,240
West Mansfield, OH
Well, it was dry enough to get most of the grass cut. Took the B1700 for a spin and knocked it down. First time in two weeks. IMG_7130.jpeg
Reactions: 6 users
Sidekick
Jul 29, 2023
1,287
1,866
N.Y,
I keep the 3 saws, batteries, chains, wedges, oil, and chaps in that aluminum box I mounted in the RTV trailer hitch. Don't take the new tractor in the woods because of the cab and all the crap that blows off the dead ash.
