"As the World Turns"............
5,552
Now because I can't help but to stay busy, and sleep is not yet on my radar, and since I am awaiting various parts/pieces.....
In my infinite wisdom, I decide to start yet "another project"
I need a "fume hood" in the worst way for my CNC Plasma cutter.....
As the projects begin to increase in "scope and magnitude" (whatever that means 🤷‍♂️ ).....I finally "choked myself out" of the basement the other day, making my "new and improved" Brush Guard out of SS.
It only took about 2-3 minutes to cut out......BUT DAMN HOME-BOY....that really flooded the basement with fumes....Like I have never seen before.....
So it's "time"........
I gotta get some sort of "fume hood" going....and quick.
So I have this window that I plan to use.....I'm not sure "exactly how" yet, but it will come to me I am sure....(I think I will need to "bust out" some blocks...but we will see)
So it's off to the "Depot" and I start grabbing some various lumber.....I really should plan this better, but its just one of those things that will have to "build itself" as I go.
I start with a "cage", suspended from the 'ceiling"......I put up "my version" of what I belive 'real carpenters" call a "story board".....
Its basically a guide to help me "see into the future"....(hard to explain🤷‍♂️)
Then, in my head, I go over a few "designs" that make sense to me....Square, rectangle, sloped,....blah, blah, blah..........
I settle on a "sloped design" due too.......well I dunno....the "Venturi Effect" keeps running through my head, and it just makes sense to me.....LEAVE ME ALONE!!!!!!:ROFLMAO::ROFLMAO:
So it's off to the "new" 12 inch Sliding Compund Miter Saw......I don't actually know "how to use it" properly...but damn its nice.
I start "sawing and screwing" like I know what I doing...(but i don't really🤫)
In a "little while", this shell pops out, with the "initial placement" of the fan.
But as you can see....."Houston....we have a problem...."
Some of the houses "duct work" is in the way..........
No problem....I have some tools for that......
So a short while later.............This happens.
Then I just "re-cap" the end.
Which obviously leads to "The Next Problem".....the "heater duct' for one of the kids rooms is right behind it.......DAMN IT!!!!!!!
But the reality was, it was pretty obviously a "known problem", before I cut that "duct work"
Now at this point, I decide that since "my kids" are not living at home any longer, I have no reason to "fret" removing that duct.....
If that room is a "little colder"....basically "Who F'ing cares"....it's filled with boxes of old pictures and shit that my kids will have to throw in a dumpster when I am "room temperature".....So out comes the screw gun.......
Now its time to start "framing" the hood...............
Well I am "sad to report" that I can't decide on what to do, but basically I decide that this is going to be a "custom hood" made for 1 guy, and 1 guy only......ME......
I would like to say that I stopped and "figured out" all the geometric shapes,....and did all the math, and that I was a superstar....But it "ain't so".
I stuck up a diagonal board, stood in front of it, and marked it for my height with a Shourpie (notice that I use "knock off" Sharpies :ROFLMAO: )....And that will be its height and angle(s)
(Ran out of picture room....continued on next page)
5,552
Now for a few "educated guess" cuts, and we have the "basic shape" comiing along nicely.
I check for "interference" with the CNC machine, and it seems like it will clear.
If I have to shorten it a few inchs...oh well....Lets "cross that bridge, IF we come to it"
Welp.....FIL just called.....His motherf________g garage ceiling just fell down, and YEP.......You guessed it.......I gotta go over and see what the F is going on.....
To be continued.................
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
Yeah, plasma fumes are a really small particulate that is hard to filter and probably not good for the lungs. One suggestion I would offer is to try and capture the fumes as close to the torch as possible. Another thing to consider is the air that you exhaust has to be replaced, meaning you have to have an opening to the outside to let fresh air in. Think about a heat exchanger that could pull some heat from the exhaust to cushion the heating bill in winter. Good luck!
Tughill Tom
B3200
Dec 23, 2013
1,483
2,173
Turin, NY
Why not drop a $1K on a Fume Extractor and be done?
5,679
I like the fact you have a Pittsburgh potty right there
Workerbee
Zd21
Mar 1, 2020
387
272
MN
That ‘sawing and screwing’ sure sounds like a lot of fun! But Im really wondering here, did you help your FIL put that ceiling up?
LFP57
LX2610 Land pride QH 10, BB1560, EA 55" Wicked Grapple, Top n Tilt, Wicked T
Sep 21, 2021
165
79
Are you married, if so, how to manage to avoid the wrath of your wife coming down onto you for all the noise and fumes coming from the basement?
#40Fan
656
484
As long as the washer and dryer aren't in the basement, there isn't a reason for her to be down there.
But, since they were in my old house, I always did the laundry.
11,245
Sorry, I know you'll call this a nanny post, but.:whistle:
I'm wondering when (not if) he burns the house down with that fine contraption!
Never a good idea to extract burning anything:
#1 with a harbor freight fan (or any other fan for that matter) that's not rated for the job it's being used for. :oops:
#2 with a wood enclosure! :eek:
5,552
Yes sir, I considered that. I am planning on having another fan to bring in some outside air while its running.
I like making stuff.....Even if it's a failure,......I like the thrill of the hunt I suppose. 🤷‍♂️
Besides that, how would I justify buying one of these if I just bought a system.
Still waiting for it to show up....Damn Vevor shipping.....(I am hoping they don't cancel it)
Hahahah.............Good point my man!
No, I was 18 months old when apparently these guys showed up to build that house....and the joists look like it too......:ROFLMAO:🤷‍♂️
No worries man, I always like to hear ideas and suggestions....Whether I like/listen to them or not is irrelevant, they at least make me think.
I will have it wrapped in sheet metal, both inside and out, so I think I'll be good there. The framing was/is just to have something for the sheetmetal to "cling to".
The fan is an "Vevor Special Explosion proof fan" that was/is for my "paint booth"...It moves tons of air.
5,552
Man, I love that thing!!!
That thing saves so many trips "upstairs", it's not even funny...It was actually"intended" for a "finished basement" when I built the house...But things went a "wee bit different direction" ;) (y)
You should have seen the day she came home from work and the garage ceiling, was on the floor, and a 10,000 pound hoist was sitting in a box in the driveway.......Now that was quite a "conversation"🤔👏:ROFLMAO:🤷‍♂️
5,552
ASIDE: It's funny how "yoot's" think (or don't think;))
Me and the Old Lady demo'd the FIL's ceiling, found a few "less than quality" 1970's stoner built truss's.
I figure we can shore them up nicely, so I rent a scaffolding, and call my SIL over to help.
Here is the scaffolding.....Nice stuff from The Depot......
But here is SIL......climbing like a monkey.....refusing to use the scaffolding sitting 10 feet away......
He said "It's faster, my way"........:cautious:🤔.....🤷‍♂️🤷‍♂️
6,323
in one picture ,it looks like cold air return is overhead and not sealed. That's 'interesting'.........
side note.... wife USED to do woodworking in our basement. Whole house got dusty. So...I spent the money and time to install a fine filter overhead air filer, 'toner' rated shop vac and dust collection systems. Built a downdraft sanding table as well...IF you powered them up ,you could see anywhere in the basement. Even put 'shop vac' in a carpetted cupboad(super quiet). She never used any of it....
All gone.... still complains 'dust in the house'......
Sidekick
Jul 29, 2023
1,287
1,866
N.Y,
Is it legal to blow that stuff outside in a HOA ?
