If you had to pick…
ayak
L3301 HST
Feb 16, 2018
788
1,302
WV
…or if you have any other sage advice….
the time has come to replace the Oil Separator element in my L3301 (pictured here wrapped in foil).
I need to get access to the bottom section to first remove the clamped hose, so I can next unscrew the bottom cover to pull out the element.
Looks like I can either take the air intake hose off on one side, or instead, remove the upper radiator hose.
Anybody done this who could offer advice?
11,243
The air intake pipe or just remove the the mounting bolts for the separator.
ayak
L3301 HST
Feb 16, 2018
788
1,302
WV
I wondered about the mounting bolts too, but I reckon they’d be nice to have on while wrenching off that lower cover the drain hose connects to.
3,778
2,183
I remove the 3 6 mm mounting bolts and lift it. A pair of 480-channel locks will comfortably hold it while unscrewing the cap.
