B7200 rear lift problems solved
orangeEarl
B7200
Aug 1, 2026
I created a YouTube video documenting how I repaired my 3 point lift. I ordered the parts from my local Kubota dealership. My lift was weak, would creep down severely, and wouldn’t work at all sometimes. After replacing the piston o rings it works flawlessly and has all the power available.
You might think this is an involved process or difficult but it’s not at all it took me less than 45 minutes start to finish.
Kubota B7200 3-Point Lift WEAK & Creeping Down? Easy Hydraulic Fix
11,135
You really need change the hydraulic fluid.
Your fluid is highly contaminated.
orangeEarl
B7200
Aug 1, 2026
You are correct. I’ve been going through the tractor little by little. I have a 5 gallon bucket of UDT in my truck right now.
I believe I was getting water intrusion through the shifter because my boot was badly damaged but I ordered a new one and replaced it.
