rtv-500
silver
rtv-500
Jun 5, 2026
texas
blows one fuse everytime you turn ignition switch its the fuse that powers the engine control, fuel pump, radiator fan went through the whole harness and didnt find a short also replaced the fuel pump and ign. switch help
silver
rtv-500
Jun 5, 2026
texas
Hey mike thanks for the help let me tell you what happened . i had put a battery cutoff down by the ebrake
while i was riding it i thought my ebrake was on so i reached down and hit the cutoff at full speed and it shut off stoped and fliped the cutoff on and wouldnt start at all. checked fuel pump not working checked
fuses and a 10 amp was blown it runs the ecu,fuel pump, fan motor relay. replaced it and as soon as i turn
ignition to on it blows every time. i replaced the pump check all the harness shorts do you think ecu shorted out
4,152
2,843
Go ask AI to solve your problem. AI tends to give useless verbose answers based on being given not enough information to solve a problem. Enjoy your new part swap hobby.
Clutch
L2900, RTV500, T2380
Oct 21, 2024
60
17
NY - USA
Try and remove that cutoff from your circuit and see if it keeps blowing fuses. Maybe that is grounding you out and causing the issue?
K5ZZR
Z726x
My new ignition switch was the wrong one and kept blowing the 30A fuse that is just before the switch on my Z726x. Do the continuity check listed in the wiring diagram and I bet you will see some shorts that shouldn't be there. The 5 digit serial number drawings are slightly different than the more recent longer numbers. Good luck...
I got the new ignition switch from Kubota and now no problems. My previous online purchase of the Ignition switch falsely stated it was OEM on the non Kubota website but it came in an unmarked bag and proved to be a crappy substitute that kept blowing fuses. Live and learn I guess...
